Sony Bravia KDL50W805, problems with some subtitles
Azazel
Post Mon May 18, 2015 1:25 pm
im new to this forum and hope you can help me because i already searched google and some topics like this "...with greek subtitles, etc.".
Im using Servio Pro and a Sony Bravia KDL50W805 television.
Mostly i watch anime that has japanese vocals and german/english subtitles.
The problem is, that there with some subgroups, the subtitles only work on my computer with VLC player.
Have you any ideas how to fix this problem, because Serviio is really great for my media at home.
This is the last issue i have.
Best regards
Thomas
Post Mon May 18, 2015 5:49 pm
Re: Sony Bravia KDL50W805, problems with some subtitles
Not sure to understand your problem...
Do you set preferred langage on serviio console Delivery/Subtitle tab ?
Could you provide detailed information about a file format? (see signature link...ffmpeg -i and Mediainfo tools result)
Could you check on detailed logging if your file was delivered in native format or transcoded ?
Azazel
Post Tue May 19, 2015 9:10 am
Im sorry that I cant explain my problem that good.
Im not good in this genre.
I think i did the right settings, but im not sure about this.
But i made a screenshot for you.
Maybe something like type in, german, ger, de can help here?
Saw this hint in the forum after searching for a while.
C:\Programme\Serviio\lib>ffmpeg.exe -i "Q:\Anime\ShingekiNoKyojin\Staffel 1\AoT1
.mkv"
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
libavutil 54. 14.100 / 54. 14.100
libavcodec 56. 12.101 / 56. 12.101
libavformat 56. 14.100 / 56. 14.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
Input #0, matroska,webm, from 'Q:\Anime\ShingekiNoKyojin\Staffel 1\AoT1.mkv':
title : [Chinurarete Subs]Shingeki no Kyojin Folge 1 - Die Agonie
Shiganshinas Ôæá
encoder : libebml v1.3.0 + libmatroska v1.4.0
creation_time : 2013-05-19 13:09:48
Duration: 00:24:19.54, start: 0.000000, bitrate: 3255 kb/s
Chapter #0:0: start 0.000000, end 122.532000
title : Einleitung
Chapter #0:1: start 122.532000, end 215.430000
title : Opening
Chapter #0:2: start 215.430000, end 1430.537000
title : Hauptteil
Chapter #0:3: start 1430.537000, end 1446.486000
title : Vorschau
Stream #0:0(jpn): Video: h264 (High 10), yuv420p10le, 1280x720 [SAR 1:1 DAR
16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : Video
Stream #0:1(jpn): Audio: aac (LC), 48000 Hz, stereo, fltp (default)
title : Audio
Stream #0:2(ger): Subtitle: ass (default) (forced)
title : Farbsub
Stream #0:3(ger): Subtitle: ass
title : Kein Farbsub
Stream #0:4: Attachment: ttf
filename : AGaramondPro-BoldItalic_0.otf
mimetype : application/x-truetype-font
Stream #0:5: Attachment: ttf
filename : AGaramondPro-Italic_0.otf
Stream #0:6: Attachment: ttf
filename : AGaramondPro-Regular_0.otf
Stream #0:7: Attachment: ttf
filename : amerigo-bt.ttf
Stream #0:8: Attachment: ttf
filename : TIB___.TTF
Stream #0:9: Attachment: ttf
filename : Times Bold.ttf
Stream #0:10: Attachment: ttf
filename : AGaramondPro-Bold_0.otf
Does that information help you?
Thanks for your help.
Best regards
Thomas
Post Tue May 19, 2015 9:52 am
Then if you want that german subtitle ("ger") be burned in transcoding output, I suggest to add ger value on "bevorsugte Sprache" field.
Azazel
Post Tue May 19, 2015 11:44 am
I will try this when I am home later.
I'll give you feedback then.
Azazel
Post Tue May 19, 2015 7:10 pm
I tried this out, but it's still not working.
There isnt any change.
No subs are shown if i watch it over Serviio.
Whats next i can try?
Here is a ffmpeg from another mkv file where subtitles are working
C:\Programme\Serviio\lib>ffmpeg.exe -i "Q:\Anime\GrisaiaNoRakuen\Grisaia_no_Raku
en_01.mkv"
Input #0, matroska,webm, from 'Q:\Anime\GrisaiaNoRakuen\Grisaia_no_Rakuen_01.mkv
encoder : libebml v1.2.2 + libmatroska v1.3.0
creation_time : 2015-04-19 21:30:48
Duration: 00:23:40.55, start: 0.000000, bitrate: 1907 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98
Stream #0:1: Audio: aac (LC), 44100 Hz, stereo, fltp (default)
Stream #0:3: Attachment: ttf
filename : LETT____.TTF
mimetype : application/x-font-ttf
filename : Fontin_Sans_SC_45b.ttf
filename : Fontin_Sans_R_45b.ttf
filename : Fontin_Sans_I_45b.ttf
filename : Fontin_Sans_BI_45b.ttf
filename : Fontin_Sans_B_45b.ttf
filename : aparaj.ttf
filename : andlso.ttf
Stream #0:11: Attachment: ttf
filename : OpenSans-Semibold.ttf
Post Wed May 20, 2015 5:57 pm
Could you enable detailed logging and check the serviio.log file to find the ffmpeg command line used during transcoding ?
Azazel
Post Thu May 21, 2015 7:59 am
Thanks for your response Illico.
Here you can download the serviio.log file i created.
http://uploaded.net/file/42383c3y
I hope its ok like this.
If you want to, i can upload you one of the media files that don't give subtitles too.
Just tell me how to support you with your work. :)
Best regards
Thomas
