Duplicates when adding a sub folder
flexi
Post Tue May 19, 2015 2:05 pm
Since I started using Serviio, I'm using a library folder setup like this:
D:\User\Movies\Download\000 [x] [ ] [ ] "WatchNow"
D:\ [x] [x] [x] "BrowseAll"
In words: I have a lot of files in D: and want a quick link to some files in a subfolder.
I understand this is not longer supported in Serviio 1.5.
But it's obviously only a check on the client console.
My old configuration worked perfectly in Serviio 1.5.1. and 1.5.2 until I tried to add a new online resource.
Now the console is telling me I have duplicates.
And since I removed the entry D:\ - my working configuration is gone for good. :cry:
Please help me, can you fix this? :o
Console could report an information of duplicates (and proceed saving) instead of canceling the Save procedure at all.
Or is there a possibilty so send an "add folder" request via CURL or something?
Post Wed May 20, 2015 8:33 am
Re: Duplicates when adding a sub folder
That is not supported anymore due to the changes of scanning library in 1.5.x. It will not come back I'm afraid.
flexi
Post Wed May 20, 2015 11:19 pm
But scanning those directories works fine.
It's just the AddDir what's checked and cancelled. :-(
