Weird issue when using my WDTV Live
joe33067
Post Thu May 14, 2015 9:39 am
Ever since switching to Servioo v1.5.2 (previously I was using Twonky v6) I haven't been able to use the built in search feature of the WDTV. This is the search feature which, when used, you can either specify "Starts with" or "Contains", and all matches as you type them on the virtual keyboard will be displayed. Is it because Servioo tries to display titles using metadata ?
Is anyone aware of any incompatibilities between Servioo and WDTV ?
I've started with Servioo v1.5.2 Pro Eval, and now it's converted to v1.5.2 (free). I'm running in on Windows 7, and I have the media folders indexed.
joe33067
Post Sun May 17, 2015 9:28 am
Re: Weird issue when using my WDTV Live
Does anyone use WDTV ?
bobsmo
Post Mon May 18, 2015 10:51 am
I do use the WDTV in one of my rooms with a non-smart TV (ie no wifi or ethernet) just perfectly, but do not use any search function.
joe33067
Post Mon May 18, 2015 11:27 am
Are you using Serviio under Windows or Linux? What version of the OS are you running?
If possible, if you could do a quick test with your WDTV and try using the search button (lower left hand corner of the remote, the "magnifying glass"), that would be great.
Joe
bobsmo
Post Tue May 19, 2015 4:24 pm
Not sure if I did it right, but if I search for anything starting with "H" for example, I get everything in my library back, whether it begins with "H" or not.
joe33067
Post Wed May 20, 2015 7:57 am
Well that's the exact opposite of what I am seeing. Let me ask you this - when you go into the search feature, on the left hand side you have a virtual keyboard, and on the right hand side, would be where the list of matching titles is displayed. My initial matching titles, instead of listing the movies, lists "Audio, Image, Video". I think this is where the problem is - I'm just not sure how to get around it.
Are you seeing the same thing ?
bobsmo
Post Wed May 20, 2015 9:37 am
joe33067 wrote:Well that's the exact opposite of what I am seeing. Let me ask you this - when you go into the search feature, on the left hand side you have a virtual keyboard, and on the right hand side, would be where the list of matching titles is displayed. My initial matching titles, instead of listing the movies, lists "Audio, Image, Video". I think this is where the problem is - I'm just not sure how to get around it.
Yes.
joe33067
Post Wed Jun 17, 2015 9:41 am
I'm stumped. I've tried changing the folder structure, I've tried using network mappings in Serviio (instead of drive letters)... nothing makes a difference.
Users browsing this forum: No registered users and 102 guests
