Sony 50W656A
spluff
Post Wed May 20, 2015 11:40 am
Sony 50W656A
Hi all,
Thanks for this great product - Im new here :)
I have a Sony 50W656a and installed Serviio on my PC - I plan to stream mkv using homeplugs.
Just a few questions:-
a. How do you know the quality the stream is streaming on the TV is?
b. The MKVs are in dd5.1 - will the audio output be in dd5.1
c. If the network is very good will the quality be just as good as connecting hard drive via USB?
d. Not Sony related but maybe can help - How do you stream videos on another PC?
e. If the harddrive goes into sleep mode will it activate it?
Many thanks
Post Wed May 20, 2015 6:04 pm
Re: Sony 50W656A
Do you try first with direct connection between your PC and Sony TV ?
Then with homeplugs in futur, only network bandwidth should be deteriorated (depending of device capabilities), so if you stream high quality video (mkv HD h264 > 4.2 profile) you should have some stuttering.
spluff
Post Fri May 22, 2015 7:13 am
Re: Sony 50W656A
Yeah I did but I really would like an answer to all my questions please so I can work out what is happening :)
