Can I make a backup of the Serviio DB
HansDreve
Post Fri May 22, 2015 9:19 pm
Hi All,
I think the answer is already somewhere in this forum, but I was unable to find it, sorry.
My problem is that I need to re-install Windows. Installed the wrong version of Server 2012 (I have a licence for Standard R2 but with my stupid head I installed the Datacenter R2 version).
Since it is not possible to install the standard over the datacenter, I have to re-install everything.
The DB of Serviio is a bit big, takes about three days to build again. If I can avoid that, it would be great.
In this case the hardware config will stay the same as it is now, so also the locations of all the folders, so an backup now and restore later should be possible.
Maybe that I can copy the whole Serviio folder, but I'm not sure if that is all there is, maybe there are files stored in another place, files that are needed.
If it's not possible, than that's OK as well, it's my own stupid mistake.
Thanks for your answer!
Regards,
Hans Dreve
Netherlands
stefana888
Post Sat May 23, 2015 3:01 pm
Re: Can I make a backup of the Serviio DB
You can backup whole 'library' folder. It also contains things to be consistent with the database.
