helpppp I bought a license
rodrigoitaqui
Post Tue May 26, 2015 11:13 pm
I have a problem internet explorer
{{}} {{selectedItem.title selectedItem.date | date: 'yyyy'}} {{}} selectedItem.description Playlist
containerTitle {{} {} {} {} {item.title item.duration |}} timeStringShort
rodrigoitaqui
Post Tue May 26, 2015 11:17 pm
Re: helpppp I bought a license
because it does not appear the cover of the films, the films that do not have cover not appear on tv
Sem título.jpg (266.78 KiB) Viewed 6716 times
Post Fri May 29, 2015 11:07 am
Hi, i don't understand what the problem is.
rodrigoitaqui
Post Sat May 30, 2015 1:58 am
in internet explorer browser appears this error
rodrigoitaqui
Post Sat May 30, 2015 2:00 am
I wonder also, you have a film that does not appear, only if I select to display folders.
he is without appearing movie cover
as in imegem I sent
Post Sat May 30, 2015 3:43 am
rodrigoitaqui wrote:I wonder also, you have a film that does not appear, only if I select to display folders.
I'll let zip talk to the IE error, but for the movie covers it means that the metadata (movie title, covers, etc) information is not being found. This is generally because the file name of the media file doesn't match the what is required by Serviio - see my post here: viewtopic.php?f=5&t=10626&p=70544#p70544. Renaming your files should fix the issue.
Post Tue Jun 02, 2015 1:21 pm
What version of IE are you using? Make sure its the latest.
