can't install server
leekente
Post Thu May 21, 2015 6:23 pm
hi when i download and install serviio, the console installs but not the server i can't find a separate download for the server.
i have used it before successfully and would like to upgrade to pro.
thanks lee
Post Fri May 29, 2015 11:08 am
Re: can't install server
Are you on a Mac? If yes, the server is installed as a daemon process, it doesn't have an icon under Applications anymore.
leekente
Post Sun May 31, 2015 11:06 am
yes i am on mac, installed it but couldn't get it to connect to sony tv also could not open the console for the options?
will try again very frustrating as i using ps3 server at the min no where near as good as serviio imo..
its just saying "can not connect to server it dose not seem to be running" exiting
thanks lee
Post Wed Jun 03, 2015 3:26 pm
