Latest Edition Not opening
weekendwarrior
Post Thu May 28, 2015 11:12 am
Hi guys, Im running the latest version and for some reason on my Macbook the console works but I cannot get the other client to work. (You know the window were you specify the media folder you want etc) it literally is nowhere to be seen now. I canot find it. There is nothing wrong with my MacBook and this was working before I upgraded. In Servio application directory I cannot find any Servio application either which is weird. It's not in the BIN folders etc.... HELP......
TechWhizZ199
Post Thu May 28, 2015 2:17 pm
Re: Latest Edition Not opening
Try uninstalling the latest version of Serviio and installing it again. This could have been due to a faulty installation.
weekendwarrior
Post Thu May 28, 2015 9:31 pm
Hello - I have tried that offcourse. I even followed the instructions for opening the terminal window and stopping starting the service. I just cannot seem to find and open the servio agent. The actual console opens but not the other part. Can you help? Its so strange.
Post Fri May 29, 2015 11:06 am
Only the Console is in the Applications folder, that's where you add folders etc.
The server part now runs as a deamon process automatically then the Mac starts.
weekendwarrior
Post Fri May 29, 2015 12:22 pm
I got this working. However it ONLY works properly with version 1.4..... 1.5 latest does not work whatsoever..... weird.....
Users browsing this forum: Google [Bot] and 38 guests
