Can't start Serviio in Lubuntu
damobeach
Post Sat Jun 06, 2015 1:24 pm
Could anyone please help with some advice - I'm running Lubuntu 14.04.1 LTS. I've installed Serviio using the instructions found here: http://www.tylergale.com/?p=77 My problem is that I can't start Serviio. I've tried starting from the command line and from executing the files themselves from within the bin folder. Please see below for the message showed in XTerm:
damo@damo-ISTART-2390-AIO:~$ sh /home/damo/serviio-1.5.2/bin/serviio.sh
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/serviio/MediaServer : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
I'm using Java 7, update 80.
Damian
damobeach
Post Sat Jun 06, 2015 2:39 pm
Re: Can't start Serviio in Lubuntu
Hi, no need for replies. I've updated Java and can start Serviio ok
