Serviio missing on TV Samsung
angelillo64
Post Tue Mar 10, 2015 10:44 am
Hi, this is my first post if you see that does not correspond to this thread beseech you soon shaken where applicable.
Servvio and install my samsung tv UE42F5500 recognized immediately but every time I reboot the PC stop. Uninstall the program and install again and again recognized . I tried to open ports in router, firewall and even disable antivirus off and can not find solution , you can help me ? My OS is Windows 7 32 bit and my antivirus ESET Smart Security is 7. Sorry for my english (automatic translation) Thanks
Post Thu Mar 12, 2015 9:44 pm
Re: Serviio missing on TV Samsung
It sounds like the Serviio service isn't set to auto -start. Click the Start button and type "services". The Services app will appear and you can click to open it. Look for Serviio in the list and double-click it. This opens the Properties window. Make sure Startup Type is set to Automatic or Automatic (Delayed Start), and if not select it and hit Apply. Sometimes the delay helps is for some reason the network interface hasn't initialized before Serviio loads.
angelillo64
Post Fri Mar 13, 2015 7:05 am
atc98092 wrote:It sounds like the Serviio service isn't set to auto -start. Click the Start button and type "services". The Services app will appear and you can click to open it. Look for Serviio in the list and double-click it. This opens the Properties window. Make sure Startup Type is set to Automatic or Automatic (Delayed Start), and if not select it and hit Apply. Sometimes the delay helps is for some reason the network interface hasn't initialized before Serviio loads.
No, this is not the problem, the service at a startup is well set to automatic and actually starts smoothly the server PC. The problem is that my TV does not detect every time you reboot the PC. If Serviio uninstall and install again , it detected no problems.
Thanks again
Post Fri Mar 13, 2015 12:42 pm
OK, next time it doesn't appear, before trying anything else go into the Services panel and restart the Serviio service. This will ensure it's not something that is hanging it up during the reboot process. If this works, then try changing the service to delayed start.
angelillo64
Post Sun Mar 15, 2015 9:20 am
[ SOLVED ] I finally found the solution , it was open firewall ports AV ( Eset Smart Security 7) which did not know how to do it and I finally managed to do . Thank you for your contribution atc98092
Post Sun Mar 15, 2015 7:06 pm
Ah, AV can be such fun sometimes! Glad you found it, and back to enjoying your videos! :D
Gordz
Post Mon Jun 08, 2015 8:17 am
I am having the same problem Serviio works fine untill i restart my PC then my samsung H series won't see it. I have to uninstall then restall. I have tried setting the start up to delayed start but the pc just displays the message invalid parameters?
Is it a problem with eset? Can anyone help?
angelillo64
Post Mon Jun 08, 2015 1:55 pm
Gordz wrote:I am having the same problem Serviio works fine untill i restart my PC then my samsung H series won't see it. I have to uninstall then restall. I have tried setting the start up to delayed start but the pc just displays the message invalid parameters?
Watch this video>> http://kb.eset-la.com/esetkb/index?page=content&id=VIDEO88&locale=es_EN
Ports>>
8895 (TCP)
1900 (UDP)
PD: My ESET version is Smart Security 7 but the process is similar
Good Luck
Gordz
Post Mon Jun 08, 2015 10:32 pm
Many thanks. That worked!! Thanks again.
