Cannot access the server - after 10 mins of streaming
HelterSkelter
Post Thu Jun 11, 2015 9:30 am
I have read some similar issues, but haven't quite figured mine out.
I have recently set my serviio up with my Sony Bravia after moving house. It worked previously with no issues; my TV still connects to my PC, I can see and play video format, however after playing the video for about 10 mins, it will stop and I receive the error message "Cannot access the server. Please check your network settings".
The only difference is I updated Kaspersky and have a new internet provider and modem. I have already tried uninstalling then reinstaiing java and checking firewall settings and disabling the firewall & network security, but still have the same issue.
Please help - this is driving me crazy!
Lowlander
Post Fri Jun 12, 2015 12:06 pm
Re: Cannot access the server - after 10 mins of streaming
If by "new modem" you mean a new internet access router with wireless lan, you should check if it has a setting to "optimize WLAN for steaming" or something similar.
If by "new modem" you mean just a new modem, I have no idea what's going on.
| Serviio Pro 1.6 (Win Server 2008 R2, Athlon 240e, 4GB RAM, 6TB HDD) |
| Sony KDL-42W829B | Sony KDL-24EX320 | Yamaha BD-S677 | assorted iDevices |
HelterSkelter
Post Sun Jun 14, 2015 5:49 am
Yes - a new internet access router with wireless lan.
Thanks for the suggestion!!! I will do some investigation.
Cheers.
Post Sun Jun 14, 2015 11:48 am
If new router...
You can try to disable IPv6 support or try to play with UPNP, IGMP Proxy, IPV6 Multicast or IPV4 Multicast options.
