YouTube
Intel1
Post Mon May 18, 2015 6:12 pm
Re: YouTube
stefana888 wrote:
Intel1 wrote:Hi, this may help the plugin have the option to search?
https://developers.google.com/youtube/v ... earch/list
Thank you.
We know... is this feature really used from API v2?
I need youtube search from serviio :(
Hopefully they can implement search :(
stefana888
Post Mon May 18, 2015 7:23 pm
Re: YouTube
Thank you.
See first post...
rgsurplus
Post Sun Jun 14, 2015 12:40 am
Re: YouTube
Thank you guys for all your work
We here have gotten addicted to youtube without commercials
I had some understanding of api V2 ,,man the pages I had set up for some channels sometimes 10 per user ID
Well ,,I can't get my head around V3 when it comes to nextpageToken
If you would be so kind ,,now don't laugh to hard ,,
just spoon feed me so I can go back and veg on old movies
here is my serviio line as video resource
https://www.googleapis.com/youtube/v3/c ... &part=page 4
stefana888
Post Sun Jun 14, 2015 7:28 am
Re: YouTube
rgsurplus wrote:Thank you guys for all your work
Unfortunately pagetoken can not be used with channels(username) in the implementation, only with playlistitems(playlistid). You can convert that url. Note that nextPageToken value goes into 'pageToken' attribute in url.
https://www.googleapis.com/youtube/v3/playlistItems?playlistId=PLAYLIST_ID&pageToken=PAGE_TOKEN
rgsurplus
Post Sun Jun 14, 2015 6:55 pm
Re: YouTube
oh crap
have to do it the hard way ,,watch ,I'll learn enough code to get it to work and google will change it again
my dlna player used to log into youtube now it is blocked
:x :x :cry:
stefana888
Post Tue Jun 16, 2015 2:10 am
Re: YouTube
rgsurplus wrote:oh crap
:x :x :cry:
The plugin is rewritten. It is not much to learn. See first post.
dzoni
Post Sun Jul 05, 2015 5:06 pm
Re: YouTube
I've read the whole thread, but I can't seem to get the playlist working. Adding a video, or most popular works. But not playlists.
This is my API URL: https://www.googleapis.com/youtube/v3/p ... EY(REMOVED)
The playlist is Unlisted. And when I open it in the browser I can see data fed, but it won't work on Serviio.
When I use the URL that @zip provided, I get the message "Required parameter: part". Can't figure out why playlists are not working. When I don't use API I get the message Usage Limit Reached when I use API key it displays data. But either way it doesn't work on Serviio.
LOG
2015-07-05 19:34:23,049 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for http://r7---sn-ncc-cxbe.googlevideo.com/videoplayback?mn=sn-ncc-cxbe&mm=31&ratebypass=yes&mime=video%2Fmp4&pl=17&source=youtube&sver=3&expire=1436139261&dur=178.932&mv=m&mt=1436117568&ms=au&fexp=901816%2C930827%2C9407141%2C9407992%2C9408093%2C9408142%2C9408352%2C9408420%2C9408710%2C9414617%2C9415636%2C9416126%2C9416223%2C952640&sparams=dur%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Cratebypass%2Csource%2Cupn%2Cexpire&ipbits=0&ip=89.216.194.90&lmt=1427314042758719&initcwndbps=2227500&itag=22&upn=NTBKSecWolo&key=yt5&id=o-AEwswp0LKjlPTHl6nwq3BaSekHNTp2QwLhWgT649Ivg2. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:324)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:243)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:122)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:467)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:303)
   ... 3 more
2015-07-05 19:34:23,200 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for http://r1---sn-ncc-cxbl.googlevideo.com/videoplayback?ip=89.216.194.90&fexp=901816%2C916614%2C921418%2C936118%2C9406848%2C9407141%2C9408142%2C9408210%2C9408420%2C9408710%2C9409172%2C9410706%2C9413140%2C9414764%2C9415040%2C9416117%2C9416126%2C9416614%2C9416729%2C952640&sparams=dur%2Cgcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Cratebypass%2Csource%2Cupn%2Cexpire&upn=ptmFyWaPVdU&id=o-ALZH50Bxr3B_9H3OHTdX7j-_bUx2mxSAtI2c6Xo2gXPU&initcwndbps=2227500&gcr=rs&lmt=1428143745526797&key=yt5&mn=sn-ncc-cxbl&mm=31&ms=au&mv=m&mt=1436117568&source=youtube&ipbits=0&itag=22&mime=video%2Fmp4&ratebypass=yes&sver=3&expire=1436139261&dur=218.012&pl=17. It might not play.
   ... 3 more
2015-07-05 19:34:23,736 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for http://r1---sn-ncc-cxbl.googlevideo.com/videoplayback?itag=22&mime=video%2Fmp4&expire=1436139263&pcm2cms=yes&id=o-AE6UkofzfH7Ji1j72jzfio370a_4u9ZNRtJSN5lbCCQl&lmt=1428143745526797&upn=KlSJLSWRI0k&pl=17&sver=3&source=youtube&ratebypass=yes&mn=sn-ncc-cxbl&mm=31&ip=89.216.194.90&key=yt5&ms=au&ipbits=0&mv=m&initcwndbps=2227500&mt=1436117568&gcr=rs&sparams=dur%2Cgcr%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpcm2cms%2Cpl%2Cratebypass%2Csource%2Cupn%2Cexpire&dur=218.012&fexp=901816%2C9407141%2C9408142%2C9408420%2C9408710%2C9414764%2C9416126%2C952640. It might not play.
   ... 3 more
stefana888
Post Sun Jul 05, 2015 6:57 pm
Re: YouTube
@dzoni
The only thing you got to read is the thread's first post carefully. Especially under 'Playlist'.
That url is not in the correct format. That log is not coming from that url.
Lerhond
Post Sun Jul 05, 2015 7:19 pm
Re: YouTube
How about YouTube live streams? I tried doing it as in "Videos by id's" section in the first post, but the folder appeared empty.
stefana888
Post Sun Jul 05, 2015 8:16 pm
Re: YouTube
Lerhond wrote:How about YouTube live streams? I tried doing it as in "Videos by id's" section in the first post, but the folder appeared empty.
Zip haven't added support for http live streaming from youtube-dl sources yet.
dzoni
Post Sun Jul 05, 2015 10:03 pm
Re: YouTube
stefana888 wrote:@dzoni
Alright so I've figured out that I don't need anything else than the playlist ID. And it is pulling data. However I am still stuck with ffmpeg, I have no idea what on earth is the problem with it. I tried doing ffmpeg -i on one of the URLs that are shown in the error, every time among other data I get Error: 403 - Forbidden.
Did anyone experience any of this?
stefana888
Post Mon Jul 06, 2015 1:45 am
Re: YouTube
@dzoni
Maybe update ffmpeg. Btw restricted content i.e. music videos doesn't play.
edsenos
Post Mon Jul 20, 2015 4:57 pm
Re: YouTube
Hey guys! Is it possible to have my "liked videos" list with this plugin? Sorry for my english, portuguese speaker here! Thanks!
Via Tapatalk
stefana888
Post Mon Jul 20, 2015 6:57 pm
Re: YouTube
edsenos wrote:Hey guys! Is it possible to have my "liked videos" list with this plugin? Sorry for my english, portuguese speaker here! Thanks!
Via Tapatalk
Enter its playlist id in the url (see first post).
edsenos
Post Mon Jul 27, 2015 2:24 am
Re: YouTube
Via Tapatalk
It doesn't works...
Tried url https://www.googleapis.com/youtube/v3/p ... pXBfbRxZIg and nothing...
Playlist URL: https://www.youtube.com/playlist?list=L ... pXBfbRxZIg
stefana888
Post Mon Jul 27, 2015 3:20 am
Re: YouTube
edsenos wrote:
Via Tapatalk
It doesn't works...
Did you set type as "Web resource"?
edsenos
Post Mon Jul 27, 2015 11:16 am
Re: YouTube
stefana888 wrote:Did you set type as "Web resource"?
yes... :|
stefana888
Post Mon Jul 27, 2015 3:10 pm
Re: YouTube
yes... :|
It should work for sure. If no youtube at all work then the plugin isn't correctly installed.
edsenos
Post Mon Jul 27, 2015 4:54 pm
Re: YouTube
not like that, friend... the "most popular" list is ok... even a single video was tested and was ok... but that specific list, no way... can anybody else help me please?
Enviado do meu iPhone usando Tapatalk
stefana888
Post Mon Jul 27, 2015 7:13 pm
Re: YouTube
All official music videos are protected and doesn't show up....
Return to Available plugins
Users browsing this forum: No registered users and 91 guests
