FLV Problem
Alfaserviio
Post Sat Jun 20, 2015 2:30 am
FLV Problem
Please, I've problem with FLV. My WD TV play them on the USB device but the same files on DLNA server they doesen't work:
Serviio 1 5 2
Mac osx: Yosemite 10.10.2
Format : Flash Video
File size : 4.26 MiB
Duration : 41s 759ms
Overall bit rate : 845 Kbps
httphostheader : v6.lscache2.c.youtube.com
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@3.0
Bit rate : 723 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 25.024 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.094
Stream size : 3.60 MiB (84%)
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Bit rate : 124 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 630 KiB (14%)
Alfaserviio
Post Wed Jul 01, 2015 9:27 pm
Re: FLV Problem
I don't believe that nobody have this problem
