Playing MOV file with Sony BluRay
am_dew
Post Sat Jun 20, 2015 6:50 pm
I have an MOV file I'd like to play using my Sony BDP-S590 BluRay player. The file does not show up in Serviio at all when I browse the folder it is in.
Here is the FFMPEG output for the file I want to play.
Any help is appreciated! Thanks!
C:\Program Files\Serviio\lib>ffmpeg -i "W:\Junction Points\Users\Users\BDY\Downl
oads\Video\Movie1.mov"
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enab
le-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype
-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-
os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
libavutil 54. 14.100 / 54. 14.100
libavcodec 56. 12.101 / 56. 12.101
libavformat 56. 14.100 / 56. 14.100
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
Guessed Channel Layout for Input Stream #0.1 : 5.1
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'W:\Junction Points\Users\Users\BDY\Down
loads\Video\Movie1.mov':
creation_time : 2015-06-02 23:59:45
Duration: 00:55:16.98, start: 0.100104, bitrate: 42596 kb/s
Stream #0:0(eng): Video: mpeg2video (Main) (xdvb / 0x62766478), yuv420p(tv),
1920x1080 [SAR 1:1 DAR 16:9], 34899 kb/s, 29.97 fps, 29.97 tbr, 2997 tbn, 59.94
tbc (default)
handler_name : Apple Alias Data Handler
encoder : MPEG
timecode : 00:00:00:00
Stream #0:1(eng): Audio: pcm_s24be (in24 / 0x34326E69), 48000 Hz, 6 channels
, s32 (24 bit), 6912 kb/s (default)
Stream #0:2(eng): Data: none (tmcd / 0x64636D74) (default)
am_dew
Post Fri Jun 26, 2015 2:09 am
Re: Playing MOV file with Sony BluRay
No one?
Post Sat Jun 27, 2015 5:20 pm
This format is not support by your device.
mov file are usually for the mp4 and aac container.
mpepg2 are usually in mpegts container.
I suggest to remux your file in a mpegts container suppoerted by your device (try TsMuxer tools).
Users browsing this forum: No registered users and 58 guests
