run servio on a samsung bluray bd-6900
monkeyvr6
Post Sat Jun 27, 2015 5:21 pm
i got a Samsung bluray player bd-c6900 i install servio on my computer and i can see my bluray player on servio console i got 80 film folder to share how can i get in servio in the bluray player sorry im new whit that cant find the way in the player to get in servio thanks for the help
Post Sat Jun 27, 2015 10:10 pm
Re: run servio on a samsung bluray bd-6900
Make sure the proper profile is selected in the Serviio console. I've seen Samsung devices not detected accurately. Based on your model number I suggest using the Samsung C/D Series profile. Once you change the profile, make sure you click Save down at the bottom right corner of the console.
I'm not familiar with the user screen on your model, so I can't exactly tell you where to find Serviio. on my H model, there's a box along the bottom of the screen that says "Change Device". Clicking that brings up the list of DLNA enabled devices on your network. Choose the one that says Serviio (computer name).
monkeyvr6
Post Sun Jun 28, 2015 8:07 pm
the dot before the ip adress have to be green to work ???????? mine is red do it change color when the connection whit the player is ok ??????
monkeyvr6
Post Sun Jun 28, 2015 8:21 pm
i click change device but it only say no disc like if there is no other device connect i try to change the profile in serviio and it doesnt work to i reset the player after each change of profile
Post Mon Jun 29, 2015 5:56 pm
monkeyvr6 wrote:the dot before the ip adress have to be green to work ???????? mine is red do it change color when the connection whit the player is ok ??????
I have seen devices never show green, but they still work fine. The dot is not a reliable indicator of connectivity. However, red usually indicates the device isn't being seen on the network (it was at one time, or wouldn't be in the list). My Roku players always show yellow, regardless if they are streaming at the time.
monkeyvr6 wrote:i click change device but it only say no disc like if there is no other device connect i try to change the profile in serviio and it doesnt work to i reset the player after each change of profile
If Serviio isn't visible there, that makes me think there's a networking issue somewhere. If you go into Settings and check your network connection, does it say you are connected to the Internet OK? This could be why you are showing red in the console. Might check all your cables, and if using wireless make sure it's connected as well.
Users browsing this forum: Baidu [Spider] and 15 guests
