access mgmt question: does serviio offer user profiles?
hgeorges
Post Mon Jun 29, 2015 12:09 pm
Hello;
I just started exploring serviio on an unraid server installation. I've installed in a docker container, it seems to work just fine.
I want to explore all features in the pro version while it is accessible, to decide whether I should buy it. So .. I see that there is the option of setting limited access for certain directories. Is that associated with different user profiles? Can I create multiple users and customize their access?
I have another question: is there a recommended folder structure? I have a few shares (created at the root of the file system) which I want to share on my home lan: pictures (which hold also short video clips), movies, music, home video, tv recordings, documentaries, etc. Quite a few. Should I just add them one by one and chose the type of content? Is there a optimal way to organize such content to show up properly in the media browser?
Thank you for your help,
hg
Post Mon Jun 29, 2015 12:57 pm
Re: access mgmt question: does serviio offer user profiles?
There are only 2 built-in profiles - Restricted and Non-restricted. You can assign one of these to each device and then to the folders too.
hgeorges
Post Mon Jun 29, 2015 9:44 pm
Thank you, Petr. Any comments for the second part of my question re folder structure?
Post Tue Jun 30, 2015 2:51 pm
you can share just one folder with all the file types, no problem.
I personally split videos to series / movies / home videos and set metadata sources for each separately (don't want online metadata for my home videos, fo example.)
