Qnap Firmware 4.2 Beta Breaks Serviio
yogibear
Post Tue Jun 30, 2015 3:54 pm
Hi All,
Qnap have just released Beta 4.2 Technical Preview Firmware. Sadly, it breaks Serviio 1.5 Rev1
Anybody else on the Technical preview programme?
Regards,
Yogi
alleck
Post Sun Jul 26, 2015 3:09 pm
Re: Qnap Firmware 4.2 Beta Breaks Serviio
Hello
Regarding the QTS and Serviio 1.5 Rev 1. In my case (TS-253 Pro) new firmware didn't break whole service, only Servio console didn't work. I did small investigation what was wrong. Below my conclusions, and workaround:
1. I run Apache logging
2. I checked error_log and found such error "[alert] [client 192.168.1.100] /share/Web/serviio/.htaccess: Invalid command 'php_flag', perhaps misspelled or defined by a module not included in the server configuration, referer: http://192.168.1.99:8080/cgi-bin/"
3. Edited .htaccess file and commented line php_value magic_quotes_gpc off (in my case in this file was only one line).
4. Success :)
So my workaround is:
1. On Qnap side run ssh server using Qnap web console
2. Using ssh client (i.e. putty) connect to qnap as a root (in qnap root, means 'admin' account)
3. Run any editor and edit .htaccess file commenting below line, i.e.
run: vim /share/Web/serviio/.htaccess
add "#" just like that: # php_value magic_quotes_gpc off
save file (Shift ZZ)
4. Voilà !! :)
I hope, that I helped you.
Regards
Bart
P.S If whole service is not working, you can reinstall Serviio using qpkg package from this thread http://forum.serviio.org/viewtopic.php?f=14&t=5324
hybrid
Post Sun Aug 23, 2015 8:57 am
Hi
Many thanks for this! , it helped me fix my Serviio issue cause of 4.2 Beta.
I reported this to Qnap Beta Forum, but im not 100% sure its the beta or Serviio that caused it.
Can you maybe let me know who you think must solve the problem for the next beta (released this week coming).
Thanks again, super easy fix!
TVS-871 using Serviio/Mediabrowser (1.5Rev1) on IPad, Iphone, Android Phone , Samsung TV's , OTT MXQ M10 TV Box, PS4 and Xbox.
rana0971
Post Fri Oct 23, 2015 8:04 pm
Hey, I cant save the .htaccess file. Is there anything preventing me, any security issue...please help
alleck
Post Thu Oct 29, 2015 8:54 pm
HI
What does it mean that you cannot save file ? Did you log as a root (admin account) ? Any message ?
Share more information about messages.
chairmann
Post Wed Nov 25, 2015 11:04 pm
hello all. i have a ts453 firmware version 4.2.0 2015/10/23 [8gb memory].....
1. installed latest jre [8.65.0] from my app center
2. installed serviio 1.5.1 x86 version [link from this forum]
3. got fatal error on startup
4. edited .htaccess added # [/share/CACHEDEV1_DATA/.qpkg/Serviio/web_ui/.htaccess]
start serviio service [web interface] and i can see web interface but i cannot start server. get:
error: timeout
HTTP resaponse code: 0
timeout
even stranger, the device list is unpopulated.... was populated one time btw.
i'm stumped here. help appreciated. log file follows [/share/CACHEDEV1_DATA/.qpkg/Serviio/log/serviio.log]:
2015-11-25 17:53:30,646 INFO [MediaServer] ------------------------------------------------------------------------
2015-11-25 17:53:30,648 INFO [MediaServer] Serviio DLNA media streaming server v 1.5 (rev. 19ceb8acec8c)
2015-11-25 17:53:30,648 INFO [MediaServer] Petr Nejedly 2009-2015
2015-11-25 17:53:30,649 INFO [MediaServer] http://www.serviio.org
2015-11-25 17:53:30,649 INFO [MediaServer] Java 1.8.0_65-Oracle Corporation i386
2015-11-25 17:53:30,649 INFO [MediaServer] OS Linux 3.12.6
2015-11-25 17:53:30,649 INFO [MediaServer] File encoding: UTF-8
2015-11-25 17:53:30,794 INFO [MediaServer] Headless mode enabled: true
2015-11-25 17:53:30,795 INFO [MediaServer] User: admin
2015-11-25 17:53:30,795 INFO [MediaServer] User home dir: /share/homes/admin
2015-11-25 17:53:30,795 INFO [MediaServer] Temp dir: /tmp
2015-11-25 17:53:30,795 INFO [MediaServer] ------------------------------------------------------------------------
2015-11-25 17:53:31,105 INFO [WebServer] Socket buffer set to 65535 bytes
2015-11-25 17:53:31,107 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-11-25 17:53:31,286 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-11-25 17:53:31,287 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-11-25 17:53:31,334 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-11-25 17:53:31,355 INFO [DatabaseManager] Using DERBY database language
2015-11-25 17:53:33,601 INFO [MediaServer] ------------------------------------------------------------------------
2015-11-25 17:53:33,601 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-11-25 17:53:33,618 INFO [Device] Created UPnP Device with UUID: dfc7be4d-9d3d-38d2-9eb8-757e0fe88691, bound address: 192.168.1.210
2015-11-25 17:53:34,642 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-11-25 17:53:34,817 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-11-25 17:53:34,844 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-11-25 17:53:34,852 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-11-25 17:53:34,855 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-11-25 17:53:34,858 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-11-25 17:53:34,877 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-11-25 17:53:34,881 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-11-25 17:53:34,884 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-11-25 17:53:34,886 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-11-25 17:53:34,887 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-11-25 17:53:34,902 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-11-25 17:53:34,911 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-11-25 17:53:34,917 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-11-25 17:53:34,921 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-11-25 17:53:34,931 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-11-25 17:53:34,933 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-11-25 17:53:34,935 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-11-25 17:53:34,939 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-11-25 17:53:34,943 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-11-25 17:53:34,948 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-11-25 17:53:34,949 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-11-25 17:53:34,952 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-11-25 17:53:34,953 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-11-25 17:53:34,957 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-11-25 17:53:34,958 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-11-25 17:53:34,963 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-11-25 17:53:34,966 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-11-25 17:53:34,969 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-11-25 17:53:34,972 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-11-25 17:53:34,974 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-11-25 17:53:34,980 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-11-25 17:53:34,982 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-11-25 17:53:34,983 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-11-25 17:53:34,984 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-11-25 17:53:34,986 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-11-25 17:53:34,987 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-11-25 17:53:34,989 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-11-25 17:53:34,990 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-11-25 17:53:34,992 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-11-25 17:53:34,995 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-11-25 17:53:34,997 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-11-25 17:53:34,998 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-11-25 17:53:35,000 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-11-25 17:53:35,004 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-11-25 17:53:35,005 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-11-25 17:53:35,006 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-11-25 17:53:35,008 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-11-25 17:53:35,010 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-11-25 17:53:35,112 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-11-25 17:53:35,115 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-11-25 17:53:35,117 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-11-25 17:53:35,119 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-11-25 17:53:35,121 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-11-25 17:53:35,123 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-11-25 17:53:35,125 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-11-25 17:53:35,127 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-11-25 17:53:35,133 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-11-25 17:53:35,137 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-11-25 17:53:35,143 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-11-25 17:53:35,233 INFO [PluginCompilerThread] Looking for plugins at /share/CACHEDEV1_DATA/.qpkg/Serviio/plugins
2015-11-25 17:53:35,234 INFO [PluginCompilerThread] Started looking for plugins
2015-11-25 17:53:35,240 INFO [UpdateChecker] Checking if a new version is available
2015-11-25 17:53:35,307 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-11-25 17:53:35,314 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "lib\dcraw.exe": error=2, No such file or directory
java.io.IOException: Cannot run program "lib\dcraw.exe": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:248)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 1 more
2015-11-25 17:53:35,318 WARN [MediaServer] DCRAW not found. Support for raw image files will be missing.
2015-11-25 17:53:35,353 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-11-25 17:53:35,417 INFO [WebServer] WebServer starting on port 8895
2015-11-25 17:53:35,418 INFO [Device] Updated bound IP address of Device with UUID: dfc7be4d-9d3d-38d2-9eb8-757e0fe88691, bound address: 192.168.1.210
2015-11-25 17:53:35,437 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-11-25 17:53:35,437 INFO [EventDispatcher] Starting EventDispatcher
2015-11-25 17:53:35,438 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-11-25 17:53:35,490 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.1.210, timeout = 0
2015-11-25 17:53:35,497 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-11-25 17:53:35,497 INFO [RendererSearchSender] Searching for Renderer devices
2015-11-25 17:53:37,211 INFO [PluginCompilerThread] Added Web Resouce plugin Uitzending Gemist (uzg.groovy), version: 1
2015-11-25 17:53:37,460 INFO [PluginCompilerThread] Added Web Resouce plugin Disney Junior (DisneyJunior.groovy), version: 4
2015-11-25 17:53:37,951 INFO [PluginCompilerThread] Added Web Resouce plugin HDTrailers (HDTrailers.groovy), version: 12
2015-11-25 17:53:38,243 INFO [PluginCompilerThread] Added Web Resouce plugin YouTubeTop100 (Top100.groovy), version: 21
2015-11-25 17:53:38,464 INFO [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy), version: 1
2015-11-25 17:53:38,873 INFO [PluginCompilerThread] Added Web Resouce plugin TouTV (TouTV.groovy), version: 1
2015-11-25 17:53:40,433 INFO [PluginCompilerThread] Added Web Resouce plugin SvtPlay (SvtPlay.groovy), version: 20
2015-11-25 17:53:40,595 INFO [PluginCompilerThread] Added Web Resouce plugin pbskids.org (PBSKids.groovy), version: 1
2015-11-25 17:53:40,844 INFO [PluginCompilerThread] Added Web Resouce plugin CONECTATE (CONECTATE.groovy), version: 1
2015-11-25 17:53:41,055 INFO [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy), version: 5
2015-11-25 17:53:41,332 INFO [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy), version: 1
2015-11-25 17:53:41,493 INFO [PluginCompilerThread] Added Feed plugin Yahoo Movies (YahooMovies.groovy), version: 1
2015-11-25 17:53:41,566 INFO [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy), version: 1
2015-11-25 17:53:41,683 INFO [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy), version: 1
2015-11-25 17:53:41,961 INFO [PluginCompilerThread] Added Web Resouce plugin Cablevision (Cablevision.groovy), version: 1
2015-11-25 17:53:42,124 INFO [PluginCompilerThread] Added Web Resouce plugin ustream.tv (USTREAM.groovy), version: 1
2015-11-25 17:53:42,692 INFO [PluginCompilerThread] Added Web Resouce plugin OppetArkiv (OppetArkiv.groovy), version: 6
2015-11-25 17:53:43,031 INFO [PluginCompilerThread] Added Web Resouce plugin DI.FM - SKY.FM - JAZZRADIO.COM (digitallyimported.groovy), version: 2
2015-11-25 17:53:43,467 INFO [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy), version: 2
2015-11-25 17:53:43,779 INFO [PluginCompilerThread] Added Web Resouce plugin Pluzz (Pluzz.groovy), version: 18
2015-11-25 17:53:43,924 INFO [PluginCompilerThread] Added Web Resouce plugin RTL XL (RTLXL.groovy), version: 1
2015-11-25 17:53:44,282 INFO [PluginCompilerThread] Added Web Resouce plugin M6 group channels replay (M6group.groovy), version: 3
2015-11-25 17:53:44,410 INFO [PluginCompilerThread] Added Web Resouce plugin Crackle (Crackle.groovy), version: 4
2015-11-25 17:53:44,649 INFO [PluginCompilerThread] Added Web Resouce plugin CBS.com (CBS.groovy), version: 7
2015-11-25 17:53:44,922 INFO [PluginCompilerThread] Added Web Resouce plugin TeamCoco (TeamCoco.groovy), version: 1
2015-11-25 17:53:45,078 INFO [PluginCompilerThread] Added Web Resouce plugin EightTracks (EightTracks.groovy), version: 1
2015-11-25 17:53:45,236 INFO [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy), version: 5
2015-11-25 17:53:45,321 INFO [PluginCompilerThread] Added Feed plugin Radio Bremen RSS Extractor (RadioBremen.groovy), version: 1
2015-11-25 17:53:45,397 INFO [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy), version: 4
2015-11-25 17:53:45,472 INFO [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy), version: 2
2015-11-25 17:53:45,735 INFO [PluginCompilerThread] Added Web Resouce plugin ILive (ILive.groovy), version: 18
2015-11-25 17:53:45,811 INFO [PluginCompilerThread] Added Web Resouce plugin AlloCine (AlloCine.groovy), version: 1
2015-11-25 17:53:45,913 INFO [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy), version: 13
2015-11-25 17:53:46,078 INFO [PluginCompilerThread] Added Web Resouce plugin twitch.tv (twitch.groovy), version: 12
2015-11-25 17:53:46,250 INFO [PluginCompilerThread] Added Web Resouce plugin TubePlus (TubePlus.groovy), version: 1
2015-11-25 17:53:46,379 INFO [PluginCompilerThread] Added Web Resouce plugin HDHomeRun (hdhomerun.groovy), version: 4
2015-11-25 17:53:46,465 INFO [PluginCompilerThread] Added Web Resouce plugin Refresh (Refresh.groovy), version: 1
2015-11-25 17:53:46,530 INFO [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy), version: 1
2015-11-25 17:53:46,577 INFO [PluginCompilerThread] Added Feed plugin ReutersCom (ESPN Radio.groovy), version: 1
2015-11-25 17:53:46,751 INFO [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy), version: 1
2015-11-25 17:53:46,827 INFO [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy), version: 1
2015-11-25 17:53:46,880 INFO [PluginCompilerThread] Added Feed plugin PBSURLExtractor (PBS.groovy), version: 1
2015-11-25 17:53:47,263 INFO [PluginCompilerThread] Added Web Resouce plugin GooglePlus (GooglePlus.groovy), version: 2
2015-11-25 17:53:47,414 INFO [PluginCompilerThread] Added Web Resouce plugin Rage (Rage.groovy), version: 1
2015-11-25 17:53:47,465 INFO [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy), version: 1
2015-11-25 17:53:47,524 INFO [PluginCompilerThread] Added Web Resouce plugin vk.com (vk.groovy), version: 2
2015-11-25 17:53:47,587 INFO [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy), version: 1
2015-11-25 17:53:47,638 INFO [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy), version: 1
2015-11-25 17:53:47,702 INFO [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy), version: 2
2015-11-25 17:53:48,704 INFO [PluginCompilerThread] Added Web Resouce plugin Stopstream (Stopstream.groovy), version: 31
2015-11-25 17:53:48,773 INFO [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy), version: 1
2015-11-25 17:53:48,845 INFO [PluginCompilerThread] Added Web Resouce plugin veetle.com (Veetle.groovy), version: 1
2015-11-25 17:53:49,627 INFO [PluginCompilerThread] Added Web Resouce plugin CzechTV (CzechTV.groovy), version: 1
2015-11-25 17:53:52,810 INFO [PluginCompilerThread] Added Web Resouce plugin Playlist extractor (Playlist.groovy), version: 1
2015-11-25 17:53:53,363 INFO [PluginCompilerThread] Added Web Resouce plugin ITVPlayer (UK only) (ITVPlayer.groovy), version: 3
2015-11-25 17:53:53,536 INFO [PluginCompilerThread] Added Web Resouce plugin TrailerAddict (TrailerAddict.groovy), version: 15
2015-11-25 17:53:53,745 INFO [PluginCompilerThread] Added Web Resouce plugin zengatv.com (ZengaTV.groovy), version: 1
2015-11-25 17:53:53,913 INFO [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy), version: 7
2015-11-25 17:53:54,116 INFO [PluginCompilerThread] Added Feed plugin ABC (ABC.groovy), version: 1
2015-11-25 17:53:54,546 INFO [PluginCompilerThread] Added Feed plugin SvtPlayRss (SvtPlayRss.groovy), version: 1
2015-11-25 17:53:54,652 INFO [PluginCompilerThread] Added Feed plugin NBA (NBA.groovy), version: 1
2015-11-25 17:53:54,812 INFO [PluginCompilerThread] Added Web Resouce plugin TED (TED.groovy), version: 1
2015-11-25 17:53:54,901 INFO [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy), version: 1
2015-11-25 17:53:56,030 INFO [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy), version: 31
2015-11-25 17:53:56,476 INFO [PluginCompilerThread] Added Web Resouce plugin tamiltv.tv (TurboTVTamil.groovy), version: 1
2015-11-25 17:53:56,867 INFO [PluginCompilerThread] Added Web Resouce plugin desistreams.tv (DesiStreams.groovy), version: 1
2015-11-25 17:53:57,119 INFO [PluginCompilerThread] Added Web Resouce plugin BillboardTop20 (BillboardTop20.groovy), version: 6
2015-11-25 17:53:57,404 INFO [PluginCompilerThread] Added Web Resouce plugin ComedyCentral (ComedyCentral.groovy), version: 1
2015-11-25 17:53:57,500 INFO [PluginCompilerThread] Added Web Resouce plugin Sopcast (Sopcast.groovy), version: 6
2015-11-25 17:53:57,704 INFO [PluginCompilerThread] Added Web Resouce plugin Walla (Walla.groovy), version: 1
2015-11-25 17:53:57,971 INFO [PluginCompilerThread] Added Web Resouce plugin turbotv.in (TurboTVIndia.groovy), version: 1
2015-11-25 17:53:58,108 INFO [PluginCompilerThread] Added Web Resouce plugin XVIDEOS (XVIDEOS.groovy), version: 3
2015-11-25 17:53:58,332 INFO [PluginCompilerThread] Added Web Resouce plugin Stepashka (Stepashka.groovy), version: 4
2015-11-25 17:53:59,009 INFO [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy), version: 1
2015-11-25 17:53:59,199 INFO [PluginCompilerThread] Added Web Resouce plugin zonytvcom.info (ZonyTV.groovy), version: 1
2015-11-25 17:53:59,413 INFO [PluginCompilerThread] Added Web Resouce plugin discovery.com (Discovery.groovy), version: 1
2015-11-25 17:53:59,576 INFO [PluginCompilerThread] Added Web Resouce plugin cwtv.com (CW.groovy), version: 1
2015-11-25 17:53:59,702 INFO [PluginCompilerThread] Added Web Resouce plugin TELEFE (telefe.groovy), version: 1
2015-11-25 17:54:00,532 INFO [PluginCompilerThread] Added Web Resouce plugin skysportsplus (SkysportsPlus.groovy), version: 24
2015-11-25 17:54:00,687 INFO [PluginCompilerThread] Added Web Resouce plugin Disney.com (Disney.groovy), version: 1
2015-11-25 17:54:00,744 INFO [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy), version: 1
2015-11-25 17:54:00,793 INFO [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy), version: 1
2015-11-25 17:54:00,936 INFO [PluginCompilerThread] Added Web Resouce plugin RedTube (RedTube.groovy), version: 4
2015-11-25 17:54:01,015 INFO [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy), version: 1
2015-11-25 17:54:01,163 INFO [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy), version: 1
2015-11-25 17:54:01,263 INFO [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy), version: 1
2015-11-25 17:54:01,379 INFO [PluginCompilerThread] Added Web Resouce plugin Omroep NL (OmroepNL.groovy), version: 1
2015-11-25 17:54:01,434 INFO [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy), version: 1
2015-11-25 17:54:01,564 INFO [PluginCompilerThread] Added Web Resouce plugin Beeg (Beeg.groovy), version: 11
2015-11-25 17:54:01,653 INFO [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy), version: 1
2015-11-25 17:54:01,782 INFO [PluginCompilerThread] Added Web Resouce plugin Nickelodeon (Nickelodeon.groovy), version: 1
2015-11-25 17:54:02,003 INFO [PluginCompilerThread] Added Web Resouce plugin CanalPlus (CanalPlus.groovy), version: 12
2015-11-25 17:54:02,067 INFO [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy), version: 1
2015-11-25 17:54:02,203 INFO [PluginCompilerThread] Added Feed plugin ABC iView (Australia only) (ABCiView.groovy), version: 1
2015-11-25 17:54:02,365 INFO [PluginCompilerThread] Added Web Resouce plugin SeasonVar (SeasonVar.groovy), version: 6
2015-11-25 17:54:02,618 INFO [PluginCompilerThread] Added Web Resouce plugin coolsport (Coolsport.groovy), version: 21
2015-11-25 17:54:02,674 INFO [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy), version: 1
2015-11-25 17:54:02,762 INFO [PluginCompilerThread] Added Web Resouce plugin FoodNetwork.com (FoodNetwork.groovy), version: 2
2015-11-25 17:54:03,297 INFO [PluginCompilerThread] Added Web Resouce plugin myiplayer.com (MyiPlayer.groovy), version: 1
2015-11-25 17:54:03,356 INFO [PluginCompilerThread] Added Feed plugin AnOriant (AnOriant.groovy), version: 1
2015-11-25 17:54:03,542 INFO [PluginCompilerThread] Added Web Resouce plugin Syfy.com (Syfy.groovy), version: 3
2015-11-25 17:54:03,608 INFO [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy), version: 1
2015-11-25 17:54:03,696 INFO [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy), version: 2
2015-11-25 17:54:03,704 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-11-25 17:54:03,710 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-11-25 17:54:03,761 INFO [LocalLibraryManager] Starting automatic library scan
2015-11-25 17:54:03,766 INFO [LibraryDeltaScanner] Starting the library delta scan
2015-11-25 17:54:03,769 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-11-25 17:54:05,975 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.199:8888/upnp_descriptor_0
2015-11-25 17:54:35,986 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.199:8888/upnp_descriptor_0
2015-11-25 17:55:06,020 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.199:8888/upnp_descriptor_0
2015-11-25 17:55:36,061 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.199:8888/upnp_descriptor_0
2015-11-25 17:56:06,095 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.199:8888/upnp_descriptor_0
2015-11-25 17:56:36,128 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.199:8888/upnp_descriptor_0
2015-11-25 17:57:06,158 WARN [RendererManager] Error while retrieving renderer description: Cannot retrieve device description from http://192.168.1.199:8888/upnp_descriptor_0
alleck
Post Mon Dec 14, 2015 5:53 pm
Check your firewall, and check there were any port conflic with another software.
http://www.serviio.org/component/content/article/21#q1
sparkymarcopolo
Post Sun Jan 03, 2016 11:32 am
I tried this and got as far as logging in as admin....then I'm stuck how to access the .htaccess file and save (I'm using terminal on iMac)
Any help would be appreciated.
Post Thu Jan 07, 2016 2:19 pm
1.6 is coming out pretty soon and with it an official Qnap package.
