Security Password
rodrigoitaqui
Post Tue Jul 07, 2015 3:04 am
Security Password
You would not need put If the security password for remote access .. how could I disable this password ????
Post Tue Jul 07, 2015 12:26 pm
Re: Security Password
rodrigoitaqui wrote:You would not need put If the security password for remote access .. how could I disable this password ????
If you mean you want to disable requiring a password for accessing the Media Browser, I don't think you can. What you can do is check the save password box the first time you log on and it won't ask again.
Post Tue Jul 07, 2015 10:10 pm
Check out the serviio.cdsAnonymousAccess system property - see http://www.serviio.org/component/conten ... ZpY2UiXQ==. I've never tried it myself, but believe that does what you want.
Return to General discussion
