[Solved] Library automatically updated (Windows 10)
Kristian
Post Wed Jul 22, 2015 9:44 pm
When this funciton is enabled it's constantly using 10-20% CPU, even when it's done with the indexing.
Turning it off and using "Force library refresh" is doing the job as a workaround.
Can't see any one else on the forums with this issue, so might be just me. If so, anyone know what could cause this?
Post Fri Jul 24, 2015 2:32 pm
Re: Library automatically updated (Windows 10)
How many folders do you have in your library?
Is it the same with a small subset?
Kristian
Post Sat Jul 25, 2015 7:02 pm
Have about 500 folders.
Tried with only a few and the problem vanished, then I added more and more folders up to my original 500 and it seems to be a-okay! :)
Thanks!
