Help with Samsung UN60FH6200F playing 60FPS videos
vackillers
Post Mon Jan 27, 2014 10:17 pm
Keeps coming up with an error saying "Frame Rate 59 not supported" or Frame Rate 60 not supported. Plays everything else just fine that I've made, just started to use the new Nvidia Shadowplay record function for game footage but for some reason wont play via Serviio though. My older videos that are 30FPS mp4 or wmv work okay. If anyone has a profile suggestion I'm all ears, currently using the samsung tv/player (E/F Series) profile but I've tried quite a few with the same issues.
vackillers
Post Tue Jan 28, 2014 12:45 am
Re: Help with Samsung UN60FH6200F playing 60FPS videos
Here is the file info that Serviio/SamsungTV just simply won't play because it says Frame Rate 59 not supported...
<Mediainfo version="0.7.67">
<File>
<track type="General">
<Complete_name>C:\Users\VACkillers\Videos\Shadowplay\NextCarGame\NextCarGame 01.27.2014 - 18.34.43.27.mp4</Complete_name>
<Format>MPEG-4</Format>
<Format_profile>Base Media / Version 2</Format_profile>
<Codec_ID>mp42</Codec_ID>
<File_size>584 MiB</File_size>
<Duration>3mn 48s</Duration>
<Overall_bit_rate>21.4 Mbps</Overall_bit_rate>
</track>
<track type="Video">
<ID>1</ID>
<Format>AVC</Format>
<Format_Info>Advanced Video Codec</Format_Info>
<Format_profile>High@L4.2</Format_profile>
<Format_settings__CABAC>Yes</Format_settings__CABAC>
<Format_settings__ReFrames>1 frame</Format_settings__ReFrames>
<Format_settings__GOP>M=1, N=30</Format_settings__GOP>
<Codec_ID>avc1</Codec_ID>
<Codec_ID_Info>Advanced Video Coding</Codec_ID_Info>
<Source_duration>3mn 48s</Source_duration>
<Bit_rate>21.3 Mbps</Bit_rate>
<Width>1 920 pixels</Width>
<Height>1 080 pixels</Height>
<Display_aspect_ratio>16:9</Display_aspect_ratio>
<Frame_rate_mode>Variable</Frame_rate_mode>
<Frame_rate>60.000 fps</Frame_rate>
<Minimum_frame_rate>28.409 fps</Minimum_frame_rate>
<Maximum_frame_rate>105.820 fps</Maximum_frame_rate>
<Color_space>YUV</Color_space>
<Chroma_subsampling>4:2:0</Chroma_subsampling>
<Bit_depth>8 bits</Bit_depth>
<Scan_type>Progressive</Scan_type>
<Bits__Pixel_Frame_>0.171</Bits__Pixel_Frame_>
<Stream_size>581 MiB (100%)</Stream_size>
<Source_stream_size>581 MiB (100%)</Source_stream_size>
<mdhd_Duration>228597</mdhd_Duration>
</track>
<track type="Audio">
<ID>2</ID>
<Format>AAC</Format>
<Format_Info>Advanced Audio Codec</Format_Info>
<Format_profile>LC</Format_profile>
<Codec_ID>40</Codec_ID>
<Bit_rate_mode>Constant</Bit_rate_mode>
<Bit_rate>98.7 Kbps</Bit_rate>
<Nominal_bit_rate>192 Kbps</Nominal_bit_rate>
<Channel_s_>2 channels</Channel_s_>
<Channel_positions>Front: L R</Channel_positions>
<Sampling_rate>48.0 KHz</Sampling_rate>
<Compression_mode>Lossy</Compression_mode>
<Stream_size>2.69 MiB (0%)</Stream_size>
<Source_stream_size>2.69 MiB (0%)</Source_stream_size>
<mdhd_Duration>228524</mdhd_Duration>
</track>
</File>
</Mediainfo>
(hope this is the info you guys need didn't know how else to grab the media info for the file)
thanks for any help at all peeps
Post Tue Jan 28, 2014 4:23 pm
My recollection is that my Samsung could not play framerates as high as 60. Check your TV manual. I had to convert my file to 30fps in order to play it.
vackillers
Post Tue Jan 28, 2014 6:20 pm
Thanks for the reply.... but yes I believe the TV is actually capable of 120FPS as it is a 120htz TV along with the 240mhz Clear Motion Rate.
here is a link to the tech specs anyway : http://www.samsung.com/us/video/tvs/UN60FH6200FXZA-specs
I haven't found any options to adjust the refresh rate though if there is an option.. only the auto Auto Motion Plus which I dont know what setting to choose and no description of the fresh rate in there either.
Iveky
Post Wed Jan 29, 2014 11:36 am
that has nothing with video fps. convert videos to 30fps.
darmach
Post Thu Jul 23, 2015 9:48 am
Can serviio profiles.xml config be tweaked so it would transcode all 60fps video to 30fps on the fly?
Iveky
Post Thu Jul 23, 2015 2:18 pm
Yes, but some TVs cant FF or RW with transcoded files
Sent from my LG-P500 using Tapatalk 2
darmach
Post Thu Jul 23, 2015 2:34 pm
Iveky wrote:Yes, but some TVs cant FF or RW with transcoded files
Great, I can live with that, I guess. Can you anvise me how to do it?
Iveky
Post Thu Jul 23, 2015 3:07 pm
Force that all videos are transcoded. Search forum for proper profile to use?
darmach
Post Fri Jul 24, 2015 5:45 am
Except of forcing everything to be transcoded, is there an option to select only 60fps videos? Or transcoding everything is the only possible approach?
Iveky
Post Fri Jul 24, 2015 11:30 am
I have no time to check ffmpeg options...
darmach
Post Fri Jul 24, 2015 12:22 pm
Im not asking about ffmpeg options - Im asking about serviio profiles.xml "< matches /> attribute. So servio would attempt to transcode only 60 fps videos instead of doing everything.
You write that "you dont have the time to check ffmpeg options" - maybe it would be better if you stop writing meaningless responses, and let assist someone who actually wants to help?
"I have no time to check ffmpeg options... "
"Force that all videos are transcoded. Search forum for proper profile to use?"
"that has nothing with video fps. convert videos to 30fps."
"Yes, but some TVs cant FF or RW with transcoded files"
pfff... It can be clearly seen how did you manage to gain these 326 posts.
Don't bother to reply, unsubscribing anyway.
Users browsing this forum: Baidu [Spider] and 21 guests
