Poor Playback
Here's a u tube video of what I see https://youtu.be/FudSmTaf29k
Is this fixable or do I just have a bad video file?
DenyAll wrote:Common issue with AVI files made using certain encoders (at least for the ones happening at the beginning) - and easily fixed by remuxing the file.
Assuming you are a Windows user, the easiest way to do this is to use my WinHelper tool here: viewtopic.php?f=17&t=12136. Drag all offending files to the Remux tab, select "Remux to the same container type" and press Go!. This will recreate the file (old versions are saved as ".old" files so you can recover if this doesn't work - but 99% sure it will).
DenyAll wrote:Hmm, I was sure that would be it. Check your CPU while streaming to see its not maxing out. What LAN bandwidth do you have (wireless - if so try wired if possible).
Does it do this for other files types (MP4 etc). What profile are you using?
Complete name : C:\Users\M&R Joslin\Desktop\Media\Survivor - All-Stars\S08E14 - A Chapera Surprise.avi
Format : AVI
File size : 347 MiB
Duration : 42mn 20s
Overall bit rate : 1 147 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2439/release)
Writing library : VirtualDubMod build 2439/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : Yes
Format settings, GMC : 3 warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 42mn 20s
Bit rate : 1 004 Kbps
Width : 512 pixels
Height : 384 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.170
Stream size : 304 MiB (88%)
Writing library : XviD 1.0.2 (UTC 2004-08-29)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 42mn 20s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 39.1 MiB (11%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.72 video frame)
Interleave, preload duration : 142 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
DenyAll wrote:Can you post MediaInfo (viewtopic.php?f=5&t=4510) for an offending file? Lets see if that highlights anything.
Try remuxing it to a different container type. If nothing else works, you may have to re-encode the file.
DenyAll wrote:Nothing stands out from the MediaInfo. Did you try the other suggestions - did either work.
Users browsing this forum: Google [Bot] and 12 guests
