Windows 10
• Page 1 of 1
Hi, I want to know if Serviio is working well with Windows 10 before i decided tu Upgrade.
Re: Windows 10
sunfir wrote:Hi, I want to know if Serviio is working well with Windows 10 before i decided tu Upgrade.
I just installed Win 10 on my Test Serviio computer last night. Actually, I went to bed while it was updating, so never got a chance to test yet. I believe others have used the beta version of Windows and was generally working. I'll know more this evening when I test it out.
I'm more concerned with replacing Windows Media Center, as I used that to record OTA broadcasts. So I'll be testing replacements for that as well.
Re: Windows 10
OK, tested my install today. In general, no problems. I had a database issue that might have been related to my Serviio install being a beta version. I took it off and put 1.5.2 on and everything is working fine.
Re: Windows 10
My Serviio is working fine with Windows 10 EXCEPT that it won't read my library off my WDMyCloud drive. I'm waiting for an answer to that one.
In the meantime I'm running Serviio off of a Windows drive and under Windows 10 it works fine.
Paul
Paul
Re: Windows 10
Morden2004 wrote:My Serviio is working fine with Windows 10 EXCEPT that it won't read my library off my WDMyCloud drive. I'm waiting for an answer to that one.
Paul
It is now working after a 'logon user' change to the Serviio service.
Paul
• Page 1 of 1
Users browsing this forum: No registered users and 96 guests
