transcoding Bravia KDL-50W815
rumenchooo
Post Tue Aug 11, 2015 8:20 am
Hello everybody ,
I have a problem when Serviio make transcoding to burn-in subtitles.It works , but the resolution is smaller than the TV screen.
TV screen has resolution 1920x1080 , but when transcoding i get resolution 1280:533 !!!!
When I play the file without subtitles/transcoding , the resolution is the same as the mkv file(1920x800).
Here is the Serviio/ffmpeg transcoding command :
ffmpeg -threads auto -i Inception.mkv -y -c:v libx264 -pix_fmt yuv420p -profile:v baseline -level 3 -preset veryfast -b:v 12000k -maxrate:v 12000k -bufsize:v 12000k -crf 10 -vf scale=1280:533,pad=1280:720:0:93:black,setdar=4:3,subtitles=filename='Inception.ass':original_size=1920x800:charenc=UTF-8 -r 24000/1001 -g 15 -bsf:v h264_mp4toannexb -flags -global_header -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /Serviio/transcoding-temp-503-sony2013-ORIGINAL-16c6b9503d6afda9b81a270df01c5e8a.stf
Here is the ffmpeg -i of the mkv file:
ffmpeg version 2.7.2 Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 4.9.2 (Debian 4.9.2-10)
  configuration: --prefix=/home/rumen/programs/ffmpeg --extra-libs='-lxml2 -lexp                             at -lfreetype' --disable-shared --disable-ffserver --disable-doc --enable-bzlib                              --enable-zlib --enable-postproc --enable-runtime-cpudetect --enable-libx264 --en                             able-gpl --enable-libtheora --enable-libvorbis --enable-libmp3lame --enable-gray                              --enable-libass --enable-libfreetype --enable-libopenjpeg --enable-libspeex --e                             nable-libvo-aacenc --enable-libvo-amrwbenc --enable-version3 --enable-libvpx --e                             nable-gpl --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-am                             rwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --en                             able-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxv                             id --enable-libass --cc='gcc -m64'
  libavutil      54. 27.100 / 54. 27.100
  libavcodec     56. 41.100 / 56. 41.100
  libavformat    56. 36.100 / 56. 36.100
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 16.101 /  5. 16.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  2.100 /  1.  2.100
  libpostproc    53.  3.100 / 53.  3.100
Input #0, matroska,webm, from 'Inception.mkv':
    encoder         : libebml v1.0.0 + libmatroska v1.0.0
    creation_time   : 2010-11-22 20:33:05
  Duration: 02:28:07.95, start: 0.000000, bitrate: 13695 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 2                             3.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (de                             fault)
I would like to get the proper resolution (1920x1080) in case of transcoding.
Is it possible?
Any suggestion will be welcome.
Thanks in advance.
Post Tue Aug 11, 2015 6:05 pm
Re: transcoding Bravia KDL-50W815
What is the profile selected on serviio console ? do you try with the "US" version?
rumenchooo
Post Tue Aug 11, 2015 10:45 pm
Current profile is / Sony Bravia TV (2013/14) /.
i`v checked with / Sony Bravia TV (2012) - US /
No difference !!
rumenchooo
Post Wed Aug 12, 2015 12:36 pm
No one could help ????
Am I at the right place .. ?
Even with paid Serviio license ???
