Serviio Linux just disconnected from TV
sirkit
Post Fri Aug 14, 2015 2:20 am
Hi Guys,
I am running serviio from arch Linux PC connecting to Samsung TV. It been running fine for about 1 year. Then today in the middle of a movie it just disconnected and won't connect. It's not the network because I can connect to the serviio Linux box. When check the status I get this:-
Please could someone help
systemctl status serviio.service -l
● serviio.service - Serviio 1.4.1.2 Media Server
Loaded: loaded (/etc/systemd/system/serviio.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2015-08-13 22:26:42 UTC; 4h 50min ago
Main PID: 10132 (serviio.sh)
CGroup: /system.slice/serviio.service
├─10132 /bin/sh /usr/local/serviio-1.4.1.2/bin/serviio.sh
└─10137 java -Xmx512M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/usr/local/serviio-1.4.1.2/library -Dserviio.home=/usr/local/serviio-1.4.1.2 -classpath /usr/local/serviio-1.4.1.2/lib/*:/usr/local/serviio-1.4.1.2/config org.serviio.MediaServer
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.FileOutputStream.writeBytes(Native Method)
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.FileOutputStream.write(FileOutputStream.java:345)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEncoder.java:291)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:295)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.BufferedWriter.flush(BufferedWriter.java:254)
Aug 13 22:27:21 myarch serviio.sh[10132]: at com.sun.org.apache.xml.internal.serializer.ToStream.flushWriter(ToStream.java:299)
Aug 13 22:27:21 myarch serviio.sh[10132]: ... 31 more
sirkit
Post Fri Aug 14, 2015 10:47 am
Re: Serviio Linux just disconnected from TV
Is there anyone who can help on this please :( :( :(
Post Fri Aug 14, 2015 12:19 pm
While I can't help with this specific issue, I do suggest a little more patience. Serviio users are from around the world, and the person who may best help you might still be asleep. For example, the developer is in England, and several major gurus are in Australia or other significantly varied time zones. It could take a day or two before someone with Linux experience sees your post. ;)
floki
Post Fri Aug 14, 2015 12:54 pm
atc98092 wrote:While I can't help with this specific issue, I do suggest a little more patience. Serviio users are from around the world, and the person who may best help you might still be asleep. For example, the developer is in England, and several major gurus are in Australia or other significantly varied time zones. It could take a day or two before someone with Linux experience sees your post. ;)
A day or two, a month or two, who knows...
... viewtopic.php?f=10&t=19291
... viewtopic.php?f=10&t=19272
... viewtopic.php?f=10&t=19198
... viewtopic.php?f=10&t=19210
... viewtopic.php?f=10&t=19061
sirkit
Post Fri Aug 14, 2015 9:38 pm
Thanks for the advise
I am trying to figure it out but nit much luck I don't know why my TV won't come up with serviio.
sirkit
Post Sat Aug 15, 2015 6:20 pm
Was hoping the developer could help me please
Users browsing this forum: Google [Bot] and 31 guests
