No password asked
Troutking
Post Thu Aug 06, 2015 8:01 am
No password asked
When I use Serviigo I'm asked for the Serviio console password, but when I use my win 8.1 and 10 laptop I'm not. The content just shows up in both and im not asked for the password. Is that because they are all on the same network, or is it a setting that I have missed..? Setup; one pc/server/htpc with win7 and Serviio, and tablets an laptops, android win7 win8.1 10 und zu weiter...
TV: Samsung UE40C8705
FW: T-VALDEUC-3007.1
Post Fri Aug 07, 2015 11:55 am
Re: No password asked
There is no password for the console on Desktop.
Troutking
Post Fri Aug 14, 2015 7:56 am
Bummer...
norm
Post Thu Aug 20, 2015 6:48 am
I think he's referring to the media browser password needed to use ServiioGo ... any content via MediaBrowser you will have to create a password on the Console's Remote tab.
Sent from my HTC One M9 using Tapatalk
Troutking
Post Thu Aug 20, 2015 12:01 pm
Any pc connected to my wireless network can view and play any content shared on the pc/htpc where serviio is installed. I wished there was a password one has to use before one can do that. There isn't. So no misunderstanding here at all...
Post Sun Aug 23, 2015 8:11 am
You could disable those devices in Serviio console (if you didn't want to grant them any access) or set them to have limited access (and then define which shared folders are part of the limited access group).
Passwords won't work - Serviio is a DLNA server and even if the DLNA standard supported it (it doesnt afaik) then most DLNA renderers (TV's etc) have no means to actually entering a password.
Troutking
Post Sun Aug 23, 2015 11:55 am
DenyAll wrote:You could disable those devices in Serviio console (if you didn't want to grant them any access) or set them to have limited access (and then define which shared folders are part of the limited access group).
Good point.. thx for the tips btw..
Users browsing this forum: No registered users and 98 guests
