Subtitles Work in avi but not in mkv
Fanatic
Post Sat Jul 11, 2015 12:17 pm
Hi guys,
First of all, congratz on the software, very easy to use and to set it up. Hope it last for a long long time.
Now my problem. I have 2 Tv Panasonic (TX-L32E30E and TX-L42E5E) connected by cable to the router and computer. The L42 with profile Panasonic 2013 and the L32 with 2011, both of them subtitle enabled and with extration (cannot enable burned-in because it causes a error: file not readable). The L42 reads everything without a problem, but the l32 can read avi files with the subtitles but when a choose a mkv ou mpeg2-ps the video plays fine but it wont recognize the subtitles.
Its not the option to turn on and off on the tv, already check that.
I'm out of option, so i need some help to sort this out.
PS: I apologise for my english, i'm portuguese.
Fanatic
sparx
Post Fri Aug 21, 2015 10:02 pm
Re: Subtitles Work in avi but not in mkv
hi, did you find a solution - have similar problem?
Return to Panasonic
