Problems manually starting and stopping server and console!
freebo99
Post Mon Jun 01, 2015 1:10 pm
RE: Problems manually starting and stopping server and console!
serviio worked great before i did the below with autostart and the console worked fine as well.
i have a slower iMac and i wanted to stop the server auto starting so, i asked on the forum and was told to..
http://wiki.serviio.org/doku.php?id=mac ... _autostart
serviio automatically starts on OSX after the system boots. To disable this behaviour, follow these steps:
1 open the daemon configuration in your favorite editor: /Library/LaunchDaemons/org.serviio.server.plist
2 disable autostart by changing <key>RunAtLoad</key>
3 <true/>
to
4 <false/>
5 and save the file.
done...
then to start serviio
sudo launchctl load /Applications/Serviio-Console.app/Contents/Info.plist
but i got a error about dubious file when i did this so i had to..
sudo chown root /Library/LaunchDaemons/org.serviio.server.plist
then launchctl load seemed to work as no error appeared although nothing was confirmed that it had started but if i re did sudo launchctl load /Applications/Serviio-Console.app/Contents/Info.plist it said that it was already running, but non of my devices PC, iMac, mobile phone and TV could then not see that serviio was running.
so i.. rebooted. sudo launchctl unload /Library/LaunchDaemons/org.serviio.server.plist and sudo launchctl load /Library/LaunchDaemons/org.serviio.server.plist, still nothing worked so i tried to start serviio console it asks if is alright to allow connections clicked allow then just get error cannot connect to serviio server, it does not seem to be running. exiting.... and thats it
admin please would you help?!
thx
Post Fri Jun 05, 2015 3:52 pm
Re: Problems manually starting and stopping server and conso
You're right, I've updated the wiki page with a different solution (you need to revert RunAtLoad to true)
Cow
Post Sun Aug 16, 2015 1:57 am
zip wrote:You're right, I've updated the wiki page with a different solution (you need to revert RunAtLoad to true)
Hi zip, I'm confused by those instructions on the wiki page.
Where would I put this code:
<key>Disabled</key>
<true/>
Within this the rest of the code exactly? Does it go here like this? (see towards bottom)
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
   <dict>
       <key>StandardOutPath</key>
       <string>/var/log/serviio/serviio.log</string>
       <key>StandardErrorPath</key>
       <key>KeepAlive</key>
       <false/>
       <key>Label</key>
       <string>org.serviio.server</string>
       <key>EnvironmentVariables</key>
       <dict>
         <key>SERVIIO_HOME</key>
         <string>/Library/Application Support/Serviio</string>
       </dict>
       <key>ProgramArguments</key>
        <array>
                <string>/bin/bash</string>
                <string>/Library/Application Support/Serviio/bin/serviio.sh</string>
        </array>
       <true/>
       <key>UserName</key>
      <string>root</string>
       <key>Disabled</key>
       <true/>
   </dict>
</plist>
Or does it goes somewhere else? Thank you. I just need to stop Serviio from running every time I restart my computer. I only need to run it on occasion, not every time I turn on my machine.
Post Sat Aug 22, 2015 4:25 pm
THis looks correct - does it work?
GabrielLogan
Post Sun Oct 04, 2015 7:32 pm
zip wrote:THis looks correct - does it work?
With this
<key>Disabled</key>
<true/>
It doesn't work...
I have got this message when I start the console :
Cannot connect to Servo Server, it does not seem to be running. Exiting...
Any idea?
It would be great if the console start, and then we can start the server!
Post Mon Oct 05, 2015 8:32 am
well yes, if you disable the server it will not start and you cannot start the console (it needs to connect to the server).
