Samsung 4K UE50HU6900
Post Tue Dec 23, 2014 6:21 pm
Re: Samsung 4K UE50HU6900
The latest beta of Serviio has a new Samsung H profile, and it is working well with my HU TV, as well as my H series TV and BD player. I think the beta is close to being released, but I don't know for certain when. Fingers crossed you will have the new version soon.
Biffaboy
Post Wed Dec 24, 2014 2:15 pm
atc98092 wrote:The latest beta of Serviio has a new Samsung H profile, and it is working well with my HU TV, as well as my H series TV and BD player. I think the beta is close to being released, but I don't know for certain when. Fingers crossed you will have the new version soon.
I've applied to be a beta tester - hoping I can get this before Christmas as it will be awesome.
thebarman
Post Mon Jan 05, 2015 1:22 am
Applied to beta test also
Biffaboy
Post Fri Feb 13, 2015 9:21 pm
Well, I still am having the problem of only folders being shown, and nothing in them.
I've added what atc98092 suggested in another thread
But still, nothing.
Please see below my log file.
log-13-02-15.txt
(104.94 KiB) Downloaded 816 times
Post Sat Feb 14, 2015 1:00 am
can you see the files in the log as being added or in MediaBrowser / other device ?
Biffaboy
Post Sat Feb 14, 2015 12:11 pm
Yes on PC and other Samsung TV everything works fine.
I disabled the files being added in the log as it was huge.
On this TV it shows folders, but nothing in them. I've tried opening ports, reinstalling etc.
Post Wed Feb 18, 2015 9:40 pm
I guess it's the same no matter what browsing category you use (Folders, Movies, Last Added, etc)
Biffaboy
Post Thu Feb 19, 2015 3:13 pm
zip wrote:I guess it's the same no matter what browsing category you use (Folders, Movies, Last Added, etc)
Yep, every category. Photo,Video,Image, just shows folders but nothing inside them.
Log file is saying it's indexing them all, and that the TV is asking for them, but nothing happens.
I've tried re-installing, opening ports on both my server and the TV (I didn't have to do that for the other 2 TV's though) - so I have hit a wall.
I would greatly appreciate a solution for this.
Post Fri Feb 20, 2015 12:31 am
Does it work for you using another server, like PS3MS or Plex?
Biffaboy
Post Fri Feb 20, 2015 3:50 pm
zip wrote:Does it work for you using another server, like PS3MS or Plex?
Yes, Samsung Link, Wondershare, Plex and another but the name has gone from me! :oops:
It's like it just doesn't want to get along with Serviio.
Post Sun Feb 22, 2015 12:17 pm
Did you try with the Generic and Samsung profiles?
Biffaboy
Post Mon Feb 23, 2015 11:24 am
zip wrote:Did you try with the Generic and Samsung profiles?
Hi, Yes I have tried all Samsung and the Generic profile
dayen
Post Sun Aug 23, 2015 1:30 pm
doy you have profiles for HU series? the one posted is freezeing :roll:
thats example file
Complete name                            :*
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 9.25 MiB
Duration                                 : 52s 300ms
Overall bit rate                         : 1 484 Kbps
Encoded date                             : UTC 2015-08-16 10:24:19
Tagged date                              : UTC 2015-08-16 10:24:19
Format profile                           : Baseline@L3.0
Format settings, CABAC                   : No
Format settings, ReFrames                : 1 frame
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 51s 950ms
Bit rate                                 : 1 357 Kbps
Width                                    : 640 pixels
Height                                   : 352 pixels
Rotation                                 : 90°
Frame rate                               : 30.040 fps
Bits/(Pixel*Frame)                       : 0.201
Stream size                              : 8.41 MiB (91%)
Encoded date                             : UTC 2015-08-16 10:24:18
Codec ID                                 : 40
Bit rate                                 : 128 Kbps
Channel count                            : 2 channels
Stream size                              : 817 KiB (9%)
Encoded date                             : UTC 2015-08-16 08:14:36
Previous
