Can't play videos on IPAD when outside of my LAN (mediabrows
manoluspaguer
Post Sun Aug 16, 2015 1:57 am
First of all, hello to everybody, this is my first post. I'd like to apologise if this is thread is duplicated, I have tried to find information about this issue but have not found anything. So, in case this is new, maybe this thread can help others with the same problem :-)
I'm testing Serviio, and I find it incredible, it's a very complete software and I'm sure I'll buy the Pro version, it's absolutelly worth it. My problem is:
While I'm inside my LAN everything works fine (DLNA on my TV, mediabrowser in my tablets...), I can play videos with my Ipad, Laptop etc. So I have tried to configure my router so that I can access Serviio outside. I usually travel a lot so it will be glad if I can access all my media when I'm abroad.
I have opened the ports (8895 TCP and 1900 UDP), and I can play videos with my laptop when I'm in another network (my parent's wifi, for example). Therefore I can assume that the router configuration is OK. Then I try with my Ipad and do the following:
- Access the mediabrowser -> I see the login screen
- Type my password -> I see my folders (series, movies, etc)
- I can see the catalogue, read the information about the movies and everything is OK, but when I push the "Play" button, no video is played. The icon changes (I don't know how to say in english. It's "crossed"?)
Then I have gone to the Serviio console -> Remote tab, and tried with several configurations:
- Checking "Configure router automatically" and filling an static IP address
- Checking "Configure router automatically" and using a domain name
- Checking "Configure router automatically" and not filling anything
- Not checking "Configure router automatically"
When I save and check connectivity, I see the red cross telling me that something is wrong.
Anybody else is having this issue?
Thank you very much in advance
Post Sun Aug 16, 2015 4:56 am
Re: Can't play videos on IPAD when outside of my LAN (mediab
Test your "Configure Router Automatically" setting using something like http://www.yougetsignal.com/tools/open-ports/ to test that port 23424 is open. If it isnt, you need to manually forward that port within your router - how to do so depends on the router model - Google is your friend for that.
When you say it works at your parents (on your laptop) - your Serviio server is at home (it's not also on your laptop), and you are accessing Mediabrowser using your external IP address (or dynDNS)?- is that correct?
ps. remote access will only work with the Pro version, or while you are in your initial 15 day evaluation period.
manoluspaguer
Post Sun Aug 23, 2015 6:26 pm
the problem had to do with open ports. In the admin page of my router they appeared as open, but when I tried to access it did not work. I called to my ISP and they had to reset my router to factory settings. Then I repeated the process and everything worked fine.
Sorry for the delay to give an answer, but I have been abroad until yesterday night :-)
So everything is ok.
Thank you very much!
Users browsing this forum: Baidu [Spider], Google [Bot] and 56 guests
