Cam recorder movies files .MOV
nachotheix
Post Tue Mar 01, 2011 11:44 pm
Hi!
I want serviio transdecode these movie files in order to my TV was able to play them.
I'm a Mac user and ffmepgX doesn't give me any information ... VLC information about these files are:
- Movie: H.264 MPG-4 AVC (part 10)
- Audio: PCM S16 LE (sowt)
Cam Recorder: Nikkon D-3100
Other no displayable files:
.MOV: Codec m2v1, Linear
Cam Recorder: Panasonic
Post Wed Mar 02, 2011 7:38 am
Re: Cam recorder movies files .MOV
What is your TV model, and profile selected?
nachotheix
Post Wed Mar 02, 2011 8:37 pm
Sorry, Samsung C-Series. ... UE37C6000
Post Wed Mar 02, 2011 8:48 pm
Provide details of the file: viewtopic.php?f=5&t=1123
Use FFmpeg distributed with Serviio
nachotheix
Post Thu Mar 03, 2011 3:23 pm
Ahhh ok I'm going to use ffmeg from Serviio Package in a Mac OSX
-------- NIKKON D3100 MOVIES FILE .MOV ------------
built on Jan 12 2011 19:51:48 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/NIKON D3100/DCIM/100D3100/DSC_0132.MOV':
major_brand : qt
minor_version : 537331968
compatible_brands: qt niko
creation_time : 2011-02-26 20:18:15
Duration: 00:01:16.03, start: 0.000000, bitrate: 18782 kb/s
Stream #0.0(eng): Video: h264, yuvj420p, 1920x1080 [PAR 1:1 DAR 16:9], 18391 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
Stream #0.1(eng): Audio: pcm_s16le, 24000 Hz, 1 channels, s16, 384 kb/s
--------- PANASONIC CAM RECORDER MOVIES FILE .MOV ---------------
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/nacho/Movies/iMovie Events.localized/Cuba - Verano 2010/clip-2010-08-04 19;19;08.mov':
major_brand : qt
minor_version : 537199360
creation_time : 2010-12-20 21:47:05
Duration: 00:00:39.92, start: 0.480000, bitrate: 10526 kb/s
Stream #0.0(eng): Video: mpeg2video, yuv420p, 704x576 [PAR 12:11 DAR 4:3], 9510 kb/s, PAR 2304:1620 DAR 704:405, 25 fps, 25 tbr, 2500 tbn, 50 tbc
Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
Stream #0.2(eng): Audio: pcm_s16le, 48000 Hz, 1 channels, s16, 768 kb/s
Stream #0.3(eng): Data: tmcd / 0x64636D74
Post Thu Mar 03, 2011 3:36 pm
The first file should be transcoded with the C series profile. Can you enable detailed logging, try playing the file and check the ffmpeg command that was used? Try running that command manually and post the result.
For the second file, you can try adding this line to the first Video transcoding config in the Samsung C profile in profiles.xml:
<Matches container="mpeg" vCodec="mpeg2video" aCodec="pcm_s16le" />
It should transcode it into mpegts with ac3. If that doesn't work, post the same result as in the case above.
nachotheix
Post Thu Mar 03, 2011 9:56 pm
Ok .. perfect ... The first video format is now playable by my TV. I have problems because it's a HD movie and each 10 seconds stops play in order to buffer new content. It's neccesary a wifi-n router to play HD videos?
But the second not ..
2011-03-03 22:53:58,815 WARN [VideoDeliveryEngine] Cannot resolve DLNA format profile of the original file: clip-2009-07-22 16;51;58.mov. Message: MP4 video file clip-2009-07-22 16;51;58.mov does not match any supported DLNA profile
nachotheix
Post Thu Mar 03, 2011 9:59 pm
I've included this line
<Matches container="mpeg" vCodec="mpeg2video" aCodec="lpcm" />
because aCodec value you sent me not is valid for XML.
Post Fri Mar 04, 2011 9:42 am
nachotheix wrote:I've included this line
You're on 0.5.1 beta, so yes. I made a mistake, you have mp4 file, so it should look like:
 <Matches container="mpeg4" vCodec="mpeg2video" aCodec="lpcm" />
nachotheix
Post Fri Mar 04, 2011 7:51 pm
2011-03-04 20:50:07,298 ERROR [XmlUtils] XML Profiles.xsd didn't pass validation, reason: cvc-enumeration-valid: Value 'mpeg4' is not facet-valid with respect to enumeration '[mp4, asf, mpegvideo, mpeg, mpegts, matroska, avi, flv, wtv]'. It must be a value from the enumeration.
2011-03-04 20:50:07,298 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: org.serviio.profile.ProfilesDefinitionException: Profiles XML file is not valid (according to the schema). Check the log.
I'm going to test mp4 value.
nachotheix
Post Fri Mar 04, 2011 11:05 pm
OK Perfect.
Thanks. All is working now.
nachotheix
Post Sun Mar 06, 2011 8:00 pm
Are you going to include these lines at profile.xml file in 0.5.1 version?
Post Sun Mar 06, 2011 8:10 pm
yes
