TV series M.A.S.K seasons 1 & 2 (1985-86) showing in series
danman45
Post Wed Aug 26, 2015 1:22 am
Hello
I have been for a while now trying to add the 1985-86 kids TV series 'M.A.S.K' as a TV series in Serviio
I did have it part of my library & showed in Serviio Series folder with no issues until the was a new TV series with the same name was added to TVDB. Mask (2015)
I've tried a number of different things. removing the whole file & re-adding it, adding in the year released, changing the name format (eg M.A.S.K. season 1 episode 02, M.A.S.K. S01E02, 1 02 M.A.S.K.) plus others.
I attached my log & a screen dump to show that it does appear in Serviio in the last added folder but not in my series folder.
Can you please help me out here
cheers guys
Serviio Image.JPG (137.68 KiB) Viewed 6277 times
serviio log.txt
(431.67 KiB) Downloaded 613 times
Post Wed Aug 26, 2015 12:56 pm
Re: TV series M.A.S.K seasons 1 & 2 (1985-86) showing in ser
Have you tried placing the files in a separate folder with both the series name and year in the folder name (i.e. "M.A.S.K. (1985)" as the folder name)? I've had to do that once or twice to get the proper metadata.
danman45
Post Thu Aug 27, 2015 9:24 am
Thanks atc98092
Yeah I tried that with no luck. Still no metadata showing in my tv series serviio folder.
Post Thu Aug 27, 2015 12:47 pm
Are you naming them manually, or are you using Filebot? If you use Filebot, it is going directly to the TV database to look up the proper name format. Just another thought.
Other than that, it might help to see what the Serviio log is showing. that might mean removing the files and adding them back so Serviio has to search for them again.
Post Thu Aug 27, 2015 1:54 pm
For hard to match series you can also add the IMDB ID for the series to the path name. In this case the IMDB ID for the series is tt0088563 --> so rename your folder to "M.A.S.K. [tt0088563]" and all will be good once again in the world :D
See http://wiki.serviio.org/doku.php?id=imb ... ata_naming for further explanation.
danman45
Post Fri Aug 28, 2015 4:22 am
Thanks guys. I tried Denyal's idea & worked.
So grateful & thank you for your help
So nice to know that there are people willing to pass on their knowledge & advise
Cheers
Users browsing this forum: No registered users and 109 guests
