Serviio not connecting to TV using Linux
sirkit
Post Wed Aug 19, 2015 4:51 am
Serviio just stopped working after 15 months of no problems. Could someone please tell me what this means-:
systemctl status serviio.service -l
● serviio.service - Serviio 1.4.1.2 Media Server
Loaded: loaded (/etc/systemd/system/serviio.service; enabled; vendor preset: disabled)
Active: active (running) since Thu 2015-08-13 22:26:42 UTC; 4h 50min ago
Main PID: 10132 (serviio.sh)
CGroup: /system.slice/serviio.service
├─10132 /bin/sh /usr/local/serviio-1.4.1.2/bin/serviio.sh
└─10137 java -Xmx512M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/usr/local/serviio-1.4.1.2/library -Dserviio.home=/usr/local/serviio-1.4.1.2 -classpath /usr/local/serviio-1.4.1.2/lib/*:/usr/local/serviio-1.4.1.2/config org.serviio.MediaServer
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.FileOutputStream.writeBytes(Native Method)
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.FileOutputStream.write(FileOutputStream.java:345)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.implFlushBuffer(StreamEncoder.java:291)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:295)
Aug 13 22:27:21 myarch serviio.sh[10132]: at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:141)
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:229)
Aug 13 22:27:21 myarch serviio.sh[10132]: at java.io.BufferedWriter.flush(BufferedWriter.java:254)
Aug 13 22:27:21 myarch serviio.sh[10132]: at com.sun.org.apache.xml.internal.serializer.ToStream.flushWriter(ToStream.java:299)
Aug 13 22:27:21 myarch serviio.sh[10132]: ... 31 more
sirkit
Post Wed Aug 26, 2015 2:44 am
Re: Serviio not connecting to TV using Linux
Is it please possible someone could guide me to fixing this problem. I have not been able to use serviio for over 1 week please please some advise
Post Wed Aug 26, 2015 1:24 pm
what is in your serviio.log?
sirkit
Post Fri Aug 28, 2015 1:22 am
Thank for getting back to me below is the last few lines of the log. The rest of the log is just the same doesn't make sense because this should not stop it from running
015-08-28 02:16:02,852 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/data500/Sherlock Holmes 2009 1080p BluRay x264-sDx/Sample/sample-pic2.png). Message: Cannot read raw image file /data500/Sherlock Holmes 2009 1080p BluRay x264-sDx/Sample/sample-pic2.png using dcraw
2015-08-28 02:16:02,907 WARN [LibraryAdditionsCheckerThread] Folder '/data500/lost+found' is either not an existing directory or cannot be read due to access rights
2015-08-28 02:18:03,323 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/data500/The.Dark.Knight.Rises.2012.NTSC.DVDR-SCREAM/darkniris-scream/VIDEO_TS/VTS_03_1.VOB). Message: Unknown video codec.
2015-08-28 02:18:03,392 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/data500/Sherlock Holmes 2009 1080p BluRay x264-sDx/Sample/sample-pic2.png). Message: Cannot read raw image file /data500/Sherlock Holmes 2009 1080p BluRay x264-sDx/Sample/sample-pic2.png using dcraw
2015-08-28 02:18:03,448 WARN [LibraryAdditionsCheckerThread] Folder '/data500/lost+found' is either not an existing directory or cannot be read due to access rights
sirkit
sirkit
sirkit
Post Mon Aug 31, 2015 1:30 pm
I have managed to resolve it, i did a full system update and that fixed it :D :D
