YouTube
stefana888
Post Mon Aug 24, 2015 10:12 am
Re: YouTube
Music videos are protected and not shown.
aloha
Post Thu Aug 27, 2015 2:18 pm
Re: YouTube
Unfortunately for me it doesn't work. Even the web resources shown above on the thread. It's showing the web resource but when trying to open "server not available" on a client (TV, tablet, phone). When I'm opening the folder on a Windows machine it's showing folders but when trying to get a file list it's empty.
Here's my ffmpeg info:
ffmpeg version N-74546-g5176443 Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04)
configuration: --extra-libs=-ldl --prefix=/opt/ffmpeg --enable-avresample --disable-debug --enable-nonfree --enable-gpl --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --disable-decoder=amrwb --enable-libpulse --enable-libdcadec --enable-libfreetype --enable-libx264 --enable-libx265 --enable-libfdk-aac --enable-libvorbis --enable-libmp3lame --enable-libopus --enable-libvpx --enable-libspeex --enable-libass --enable-avisynth --enable-libsoxr --enable-libxvid --enable-libvo-aacenc --enable-libvidstab
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 58.100 / 56. 58.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 36.100 / 5. 36.100
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.10
In attachment the detailed log
stefana888
Post Thu Aug 27, 2015 4:54 pm
Re: YouTube
Provide relevant info/log.
aloha
Post Fri Aug 28, 2015 4:54 pm
Re: YouTube
OK, here's the only thing I get in the log in debug mode when starting serviio server and trying to access online stream on client as web resources.
(see attachment)
Log_pc5dczc_online.txt
(24.49 KiB) Downloaded 2068 times
stefana888
Post Fri Aug 28, 2015 8:11 pm
Re: YouTube
You should post log on refresh resource Youtube. That log has nothing to do with the plugin.
aloha
Post Sat Aug 29, 2015 11:28 am
Re: YouTube
Here what I get
seviio_log.txt
(4.18 KiB) Downloaded 2135 times
stefana888
Post Sat Aug 29, 2015 12:36 pm
Re: YouTube
aloha wrote:Here what I get
Not much... Look for errors. (Private videos is a known bug that breks the plugin.)
aloha
Post Wed Sep 09, 2015 3:47 pm
Re: YouTube
OK. As for the log no errors at all.... but it's not still working.
Combat Jack
Post Sat Sep 12, 2015 1:07 am
Re: YouTube
Whenever I show the videos by Youtube channel username the very most recent video never shows on the list. Is there an error in how the videos are counted and then listed?
Edit: didn't notice there was a newer version of the plugin since the last time I updated it. Looks like all fixed
Gregorius
Post Tue Oct 13, 2015 6:42 pm
Re: YouTube
"domain": "usageLimits",
"reason": "dailyLimitExceededUnreg",
"message": "Daily Limit for Unauthenticated Use Exceeded. Continued use requires signup.",
"extendedHelp": "https://code.google.com/apis/console"
Gregorius
Post Wed Oct 14, 2015 12:56 pm
Re: YouTube
Error during feed reading. Message: URL 'https://www.googleapis.com/youtube/v3/playlistItems?part=contentDetails%2CId&maxResults=50&playlistId=PLwhateverid' returned status code '403'
gene
Post Sat Oct 17, 2015 1:13 pm
Re: YouTube
This plugin is unique, but for me it shows no more than 50 videos in playlist.
Max number of feeds is set to "Unlimited"
For example:
https://www.youtube.com/playlist?list=P ... rZ4tgSDgP0
Thanks in advance!
NIckelino
Post Sat Oct 17, 2015 8:21 pm
Re: YouTube
Good evening,
I'm trying to get my own Youtube-Playlist into Serviio to access it in Kodi.
That's what i've done:
-I installed Serviio on Ubuntu-Server
-Copied the plugin file Youtube.groovy into /serviio/plugins/
-Added the online source https://www.googleapis.com/youtube/v3/playlistItems?playlistId=e0k0B3Id1lDps0Tt as "Web Resource"
-After adding the source I restarted the serviio service
Now I want to access it with Kodi via UPNP but I cannot see any item in my "Online" category.
Any suggestions?
Greetings
Nicke
Post Sat Oct 17, 2015 8:22 pm
Re: YouTube
That is the limit imposed by the YouTube API.
The plug-in would need to be enhanced to allow a "Start#" parameter to allow you to get the next 50 with a second Serviio request.
Post Sat Oct 17, 2015 8:42 pm
Re: YouTube
Any suggestions?
Private videos are not supported because the plugin cannot log you on to YouTube to access them.
I get PLe0k0B3Id1lDps0Tt "does not exist"
NIckelino
Post Sat Oct 17, 2015 11:21 pm
Re: YouTube
too bad...... :cry:
hope the function will come :-)
gene
Post Sun Oct 18, 2015 6:38 am
Re: YouTube
How I can do it? Where to read?
stefana888
Post Sun Oct 18, 2015 7:21 am
Re: YouTube
With the patched plugin version attached it is possible to set the maximum number of items to retrieve, 'MAX_ITEMS', in the code (>50). We don't want to implement Serviio's console "unlimited" items causing the items extraction to possibly go on forever. Errors with private videos are fixed too.
Youtube.groovy
(10.98 KiB) Downloaded 2375 times
aloha
Post Mon Dec 14, 2015 9:42 pm
Re: YouTube
Ok I don't know how the api plugin works for other however after digging on the net I get that info:
https://github.com/sameeri/Code-WebApis ... h-resource.
As I can't make any googleapi link to work on serviio I checked on the youtube side as serviio is making the request and I have this error. Anyway please try for exemple this playlist: https://www.googleapis.com/youtube/v3/p ... Me8Vtv5LKe ( I think that the link is correct).
aloha
Post Sat Dec 19, 2015 10:22 pm
Re: YouTube
PS. OK I had a small quick tour on the V3 api specs and I now know that it will a pain in the.... for any easy streaming as before :(
Return to Available plugins
