gsayer
Post Sat May 10, 2014 10:28 am
Re: PACKAGE: Serviio 1.4.1.2 - Synology NAS (ARMv5&v7 PPC In
I wonder if someone could post a dummy's guide on how I could go about trying to fix my serviio console issue above.
It did work before I upgraded the Synology OS, I am on version DSM 5.0-4482
I have uninstalled the package and re-installed, but I am still getting the below when I browse to the console.
Any help to point this Synology noob in the right direction would be greatly appreciated.
Post Edit:
Reading floppyn & Herman posts sorted out my issue.
Thanks very much indeed :D
Morbeas
Post Thu Jun 05, 2014 12:32 pm
The latest DSM update seems to have broken Serviio. Any suggestions?
ianfretwell
Post Thu Jun 05, 2014 12:43 pm
Uninstall and reinstall Java on the Synology device.
Then start the Serviio application from the 'Packages' area of the Synology interface (I'm pretty sure you'll find it's no longer running after the DSM upgrade).
Morbeas
Post Thu Jun 05, 2014 12:49 pm
Woohoo, that worked! Thank you. :)
kudykam
Post Tue Oct 21, 2014 1:25 pm
Hi, Serviio was working fine on my DSM 5.0 (NAS 213j)
After update DSM to 5.1 beta, my Samsung TV is not showing in serviio console with green dot, but yellow.
After I trun on tv, it takes few minutes before serviio is detected. When I restart serviio service (while tv is on) it shows up quickly.
BTW reinstall java 8 didnt help.
Any idea why?
WauloK
Post Sat Oct 25, 2014 3:38 am
Hi.
I have a DS414j and have installed Java SE 7 and set up the package url for Serviio but it does not appear in my Package Center under Community.
Any ideas?
TIA :)
tingelingman
Post Fri Nov 07, 2014 10:59 am
I have a new DS1815+, Intel Atom C2538, and running DS; 5.1-5004, cant find serviio in package center. where or how can i get it? Tried Java SE 6 ,7 and 8 still nothing showing.
TIA :)
WauloK
Post Sat Nov 08, 2014 3:06 am
Appears this topic is not monitored
tingelingman
Post Mon Nov 10, 2014 11:39 am
Solved it by editing the info file in the packages and adding "avoton" under arch=
arch="88f6281 armada370 armadaxp x86 bromolow cedarview evansport qoriq ppc853x avoton"
Regards
Morbeas
Post Wed Nov 12, 2014 1:56 pm
The new Java SE embedded 7 package refuses to load? I was trying to fix the false malware report by my Synology but the new package just won't load.
WauloK
Post Fri Nov 14, 2014 2:40 am
No idea where to find 'info' nor where 'packages' is
rrleesb
Post Thu Nov 27, 2014 1:39 am
I have a DS415+ and the package for serviio does not show up. I have installed java and added the source: http://packages.pcloadletter.co.uk
Any ideas?
Entenpunk
Post Thu Nov 27, 2014 3:06 pm
tingelingman wrote:Solved it by editing the info file in the packages and adding "avoton" under arch=
Regards
Hi tingelingman,
where do I find this "info file"?
Thank you for your help.
Edit:
I solved it. I found the package here: http://packages.pcloadletter.co.uk/downloads/
open the *.spk file via 7zip and edited the info file like tingelinman wrote.
WauloK
Post Sat Nov 29, 2014 3:39 am
I got it installed on my DS414j after doing the hack above but it still doesn't work properly.
olala
Post Thu Feb 05, 2015 9:49 pm
Hi I've got a D213j and a Mac. Serviio is intalled on my Nas and Serviio Console on my mac.
I can see photo in my folder but Ican't see any video on my video folder. It's empty.
What's the problem please?
Thak U
pur_berger
Post Thu Mar 05, 2015 1:32 pm
Hm - any chance to bring 1.5.1 also to synology? Well - the 1.4.1.2 is working just fine but still I'm looking forward to get the last version on my system ...
Regards
Markus
wildmatch
Post Sun Mar 15, 2015 1:45 am
HI I have used serviio for awhile now without many issues and any I have had I have found a solution on here but the problem I am having with the NAS I cant seem to see any other person having the same identical problem.
I have followed to the letter on how to install serviio on my synology DS212j. The Java loads and installs ok, the servio server installs and runs ok. I removed a version of serviio from my windows pc that I use to access my NAS and installed the latest version console only. I have gone into the serviio bin file and changed it to notepad and added -Dserviio.remoteHost=192.168.10.103 since the IP address is my NAS and 104 is the my pc.
I can see serviio (Diskstation) on all my devices which is great .
on the NAS I dont get a serviio console nor can I now get it on my PC to run. All the files on serviio (Diskstation) are empty and I can not map or add any because I can not get onto a console. I have given the user serviio permissions for all the folders and even tried moving files in the public folder but this does nothing. the log shows devices but no updating of files.
there is no serviio service on my PC
In the NAS public foder I have java ejre-7u75-fcs-b13-linux-arm-sflt-headless-18-Dec-2014.gz
NAS DSM is 5.1
windows 7 pc is 64 bit
at this time I have video station running on my nas console
what have I done wrong or what have I missed?
Please note I am only a novice when it comes to stuff like this. Only know my way around this far because of what I have read on these forums.
bodoo69
Post Sun Apr 26, 2015 6:00 pm
Hello people
Did anyone here runs Serviio 1.4.1.2 on Synology DSM 5.2 Beta :?: :?:
Serviio 1.5.x when is ready :?: :?:
I want to update from 5.1 on my DS214+ :!:
Thanks :roll: :roll:
Alaska99
Post Fri May 08, 2015 2:22 am
My only regret is to have purchased a license Serviio. Serviio is not supported by the developers as it is a user like us who do the job. There is no guarantee that Servio is installable in the future on Synology ... In my case I gave up and bought a license of Plex which is supported on Synology and rapidly updated. :roll:
Synology DS1512+ with DSM 6.0 beta 3gig ram | Blueray Sony BDP-S390 firmware M11.R.0422 | Blueray Sony BDP-BX58 | PS3 with latest firmware | Router Asus RT-AC68U Merlin firmware | Samsung TV UN65HU9000
paniko
Post Wed Sep 02, 2015 3:42 pm
Alaska99 wrote:My only regret is to have purchased a license Serviio. Serviio is not supported by the developers as it is a user like us who do the job. There is no guarantee that Servio is installable in the future on Synology ... In my case I gave up and bought a license of Plex which is supported on Synology and rapidly updated. :roll:
I have tested Plex too.. but I found that serviio is much better.. when I have done some test Plex don't seems good to transcode some type of files rather than of serviio, never a problem.. serviio trascode all :-)
I share your thoughts about the facts that was not supported by the developers and that's was not good :-) by the way #goserviio :D :D
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
