Console OSX - info.plist issue - NAS?
liftbikeramen
Post Sun Sep 13, 2015 1:26 am
I once had serviio and console installed and working. I restored my NAS and now...
Serviio says it is running on my NAS. It also shows up on my Blu-ray box.
I downloaded and installed the console only.
When I try to launch console after modifying the info. file, nothing happens. I have my OS to allow apps from anyone. So I thought maybe I was placing the modified information in the wrong area so I tried moving it to a couple of locations, it will then launch but it says it cannot connect and then shut down.
Either I am missing something or... during this time I also updated my OS to Yosemite.
I have search this forum and I can find nothing, which means I am missing something but I have traced my steps many time and cannot figure it out.
I am hoping someone know the answer to something that was so simple to do the first time around. Thanks!!
widen76
Post Thu Nov 12, 2015 6:40 pm
Re: Console OSX - info.plist issue - NAS?
This is for the 1.5.2 version. The instructions for the syntax in the info.plist is incorrect on the download page. Here's the correct syntax for the .plist file, its not a <key> variable but a <string>. Add it inside the <array> below the JVMOptions key, like this (where x.x.x.x is the NAS IP):
<key>JVMOptions</key>
<array>
<string>-Dserviio.remoteHost=x.x.x.x</string>
patters
Post Thu Nov 12, 2015 9:55 pm
I've corrected that wording now. Wordpress had also absorbed the XML tags off my example which made it more confusing.
