Serviio Installer can't be installed on this disk 1.5.2 Mac
dumdum
Post Mon Sep 14, 2015 11:00 pm
Trying to install 1.5.2 on Mac 10.9.5 Macintosh HD with no luck :evil:
"Serviio Installer can't be installed on this disk"
Previously, I had 1.5 version (no issues)
I tried everything:
[*]Permissions is OK
[*]Daemon disabled in Terminal
[*]Application trashed and cleaned
[*]Server removed
sudo rm -rf /Library/Application\ Support/Serviio
sudo rm /Library/LaunchDaemons/org.serviio.server.plist
And still no luck
Looks like the 1.5.2 Installer corrupt, Please FIX
and meanwhile, where can I download the previous versions?
dumdum
Post Tue Sep 15, 2015 10:58 am
Re: Serviio Installer can't be installed on this disk 1.5.2
I found the older versions on other sites, but all of them gives me the same:
1.5
1.5.1
and official 1.5.2
What could happened?
I had 1.5 installed and running, Too bad that I deleted a working version from my machine
Is there a way to install it manually ?
I extracted .pkg with Pacifist
Put Serviio folder in Library/Application Support/
Put org.serviio.server.plist in Library/LaunchDaemons/
Put Serviio-Console.app in Applications
But I have no idea where to put the content of JRE.pkg? (tmp/serviio)
anyone?
Post Wed Sep 16, 2015 11:43 am
Is it 64-bit machine?
dumdum
Post Wed Sep 16, 2015 12:27 pm
Yes, iMac (Mid 2011) 64-bit
+ Mavericks is 64-bit only
Post Wed Sep 16, 2015 12:38 pm
Hmm weird. The only restrictions the installer has are:
- OSX 10.8 and above
- 64bit Intel CPU
dumdum
Post Wed Sep 16, 2015 4:27 pm
Yeah, I know :(
So, as I wrote above I'm trying to place package contents manually, but stuck on JRE.pkg
Confused with /tmp/serviio and /Contents/PlugIns
Users browsing this forum: Google [Bot] and 54 guests
