no audio with aac using chaneru or RMP
duketg
Post Sat Sep 19, 2015 3:08 am
I searched the forum and didn't see anything like this, so hopefully I'm not just repeating an old problem. I have a roku 3 and I'm trying to play a .mp4 with audio encoded as aac (see first mediainfo printout below). When I try to stream this with either Chaneru or RMP I get no audio (I've tried setting the profile as both Chaneru and Roku). Most of the files I have are encoded with AC3 audio, and so I used Handbrake to re-encode the movie as a .mp4 with AC3 (see second mediainfo below). This worked fine, and I get audio.
It seems like it should be pretty easy to edit the profiles.xml file to have Serviio just transcode from aac to ac3, but I cannot seem to figure out where I should put those commands. Hopefully this is a pretty simple addition?
Thanks in advance!
Movie with AAC encoding
Complete name                            : C:\Users\XXX\Videos\Movies\Whiplash.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 3.19 GiB
Duration                                 : 1h 46mn
Overall bit rate                         : 4 271 Kbps
Movie name                               : Whiplash
Album                                    : Whiplash
Encoded date                             : UTC 2015-02-27 22:51:44
Tagged date                              : UTC 2015-02-28 00:02:20
Writing application                      : DVDFab 9.1.8.5
Cover                                    : Yes
Format profile                           : Main@L4
Format settings, ReFrames                : 1 frame
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 1h 46mn
Source duration                          : 1h 46mn
Bit rate                                 : 3 819 Kbps
Width                                    : 1 600 pixels
Height                                   : 668 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.149
Stream size                              : 2.83 GiB (89%)
Source stream size                       : 2.83 GiB (89%)
Writing library                          : x264 core 142
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=umh / subme=6 / psy=0 / mixed_ref=0 / me_range=12 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=8 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=24 / keyint_min=13 / scenecut=40 / intra_refresh=0 / rc=abr / mbtree=0 / bitrate=3819 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color range                              : Limited
Codec ID                                 : 40
Duration                                 : 1h 46mn
Bit rate                                 : 448 Kbps
Maximum bit rate                         : 453 Kbps
Stream size                              : 342 MiB (10%)
Title                                    : English (aac 5.1)
Text #1
Format                                   : mp4s
Codec ID                                 : E0
Duration                                 : 1h 37mn
Bit rate                                 : 5 788 bps
Maximum bit rate                         : 4 249 Mbps
Stream size                              : 4.03 MiB (0%)
Tagged date                              : UTC 2015-02-27 23:57:36
Text #2
Format                                   : mp4s
Codec ID                                 : E0
Duration                                 : 1h 44mn
Bit rate                                 : 4 759 bps
Stream size                              : 3.57 MiB (0%)
Tagged date                              : UTC 2015-02-28 00:01:33
Text #3
Format                                   : mp4s
Codec ID                                 : E0
Duration                                 : 1h 37mn
Bit rate                                 : 5 785 bps
Text #4
Format                                   : mp4s
Codec ID                                 : E0
Duration                                 : 1h 44mn
Menu
Codec ID                                 : text
Duration                                 : 1h 46mn
Source duration                          : 6405399
Source frame count                       : 16
Source stream size                       : 375
Frame count                              : 16
Stream size                              : 375
00:00:00.000                             : Chapter 1
00:06:51.828                             : Chapter 2
00:14:34.498                             : Chapter 3
00:24:26.423                             : Chapter 4
00:30:06.137                             : Chapter 5
00:35:43.975                             : Chapter 6
00:43:31.358                             : Chapter 7
00:46:55.312                             : Chapter 8
00:53:12.522                             : Chapter 9
01:02:37.503                             : Chapter 10
01:10:30.601                             : Chapter 11
01:14:03.605                             : Chapter 12
01:17:48.788                             : Chapter 13
01:23:06.105                             : Chapter 14
01:25:28.289                             : Chapter 15
01:31:56.218                             : Chapter 16
Bit rate mode                            : VBR
Re-encoded with AC3
Complete name                            : C:\Users\XXX\Videos\Movies\Whiplash_conv.mp4
Codec ID                                 : mp42
File size                                : 1.50 GiB
Duration                                 : 1h 46mn
Overall bit rate                         : 2 005 Kbps
Encoded date                             : UTC 2036-02-06 06:28:16
Tagged date                              : UTC 2036-02-06 06:28:16
Writing application                      : HandBrake 0.10.2 2015060900
Codec ID                                 : avc1
Duration                                 : 1h 46mn
Bit rate                                 : 1 840 Kbps
Height                                   : 668 pixels
Frame rate mode                          : Variable
Minimum frame rate                       : 11.987 fps
Maximum frame rate                       : 24.000 fps
Bits/(Pixel*Frame)                       : 0.072
Stream size                              : 1.37 GiB (92%)
Writing library                          : x264 core 142 r2479 dd79a61
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Format profile                           : Dolby Digital
Codec ID                                 : ac-3
Duration                                 : 1h 46mn
Bit rate                                 : 160 Kbps
Stream size                              : 122 MiB (8%)
Title                                    : Stereo / Stereo
Menu
Codec ID                                 : text
Duration                                 : 1h 46mn
00:06:51.953                             : Chapter 2
00:14:34.624                             : Chapter 3
00:24:26.548                             : Chapter 4
00:30:06.263                             : Chapter 5
00:35:44.100                             : Chapter 6
00:43:31.484                             : Chapter 7
00:46:55.438                             : Chapter 8
00:53:12.648                             : Chapter 9
01:02:37.629                             : Chapter 10
01:10:30.726                             : Chapter 11
01:14:03.731                             : Chapter 12
01:17:48.914                             : Chapter 13
01:23:06.231                             : Chapter 14
01:25:28.415                             : Chapter 15
01:31:56.344                             : Chapter 16
Bit rate mode                            : VBR
duketg
Post Sat Sep 19, 2015 3:13 am
Re: no audio with aac using chaneru or RMP
Crap, sorry for the double post. It appears I need more practice working my internet machine.
Post Sun Sep 20, 2015 12:10 am
This should be all that's necessary. However, the Roku profile has a similar line so you should be good. Are you using either the Chaneru or Roku profile, or the default profile? If default, change it to Roku. Roku does not advertise itself accurately, so Serviio cannot assign the correct profile without help.
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="320">
            <Matches container="mp4" aCodec="aac"/>
Users browsing this forum: Google [Bot] and 54 guests
