MediaBrowser Online Playlist broken
Sheriff Hobbes
Post Sat Sep 19, 2015 11:29 am
I've found a bug in the MediaBrowser in Serviio 1.5.2. How to reproduce:
    * Via Serviio Console / Library / Online sources, add some radio stations
    * In MediaBrowser, browse to Audio / Online
    * You will find a list of the stations you just added
    * Click on a station
    * A new window will pop up, the Playlist. The station will begin to play
    * Click on any other station
    * MediaBrowser stops working. It's not even possible to close the Playlist with the X in the upper right
    * Only way out of this is pressing the Refresh button of your browser, which will return you to Audio / Online
This only happens with the Online Playlist, all other lists work fine. This is broken in v1.5, it worked well in v1.4.
Thanks,
SH
Marriage is a three ring circus:
-engagement ring
-wedding ring
-suffering
H. L. Mencken
Post Sun Sep 20, 2015 12:37 pm
Re: MediaBrowser Online Playlist broken
Yes this is a known bug. Should be fixed in next release.
https://bitbucket.org/xnejp03/serviio/i ... diabrowser
viewtopic.php?f=6&t=18857
Users browsing this forum: Google [Bot] and 37 guests
