OS X console takes ten minutes to start
sumguy
Post Sat Aug 29, 2015 1:15 am
Hi, I just installed Serviio for the first time. The server seems to be running ok, but the console takes more than ten minutes before it shows its window. I noticed a couple of other unanswered posts in this forum saying the console won't start up on OS X.
The icon bounces in the dock for about 30 seconds, and then I see a message about allowing incoming connections, which I allow. After that... nothing. It doesn't take a lot of CPU, it's not frozen. If I choose "About ServiioConsole" from the menu, it shows me the little "about" window. But there is no main window. More than ten minutes later, the main window finally appears. No idea what it's doing the whole time! If I quit and restart the console, the same thing happens again, I have to wait another ten minutes.
I can't find a log for the Serviio-Console application. Nothing gets printed in the OS X Console.
Using a 2012 MacBook Air.
2015-08-29 00:39:05,742 INFO [MediaServer] ------------------------------------------------------------------------
2015-08-29 00:39:05,782 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-08-29 00:39:05,782 INFO [MediaServer] Petr Nejedly 2009-2015
2015-08-29 00:39:05,782 INFO [MediaServer] http://www.serviio.org
2015-08-29 00:39:05,782 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-08-29 00:39:05,782 INFO [MediaServer] OS Mac OS X 10.10.5
2015-08-29 00:39:05,782 INFO [MediaServer] File encoding: UTF-8
2015-08-29 00:39:05,783 INFO [MediaServer] Headless mode enabled: true
2015-08-29 00:39:05,783 INFO [MediaServer] User: root
2015-08-29 00:39:05,783 INFO [MediaServer] User home dir: /var/root
2015-08-29 00:39:05,783 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-08-29 00:39:05,783 INFO [MediaServer] ------------------------------------------------------------------------
Thanks for taking a look...
Post Tue Sep 01, 2015 11:23 am
Re: OS X console takes ten minutes to start
What if you right-click on the Console icon in the dock and select Open Console
sumguy
Post Sat Sep 19, 2015 10:42 pm
Sorry I took so long to answer...
For the first ten minutes, there is no "Open Console" option in the right-click menu of the dock icon. Just the standard Keep in Dock, Hide, Quit, etc.
Then after the console window finally opens, the other options such as "Open Serviio Console", "Library automatically updated", etc., show up in the right-click menu.
Post Mon Sep 21, 2015 3:54 pm
ok, check the console log pls. It's under the console application (go to Applications, right - click on the icon, browse contents)
sumguy
Post Mon Sep 21, 2015 6:43 pm
I don't see any log file inside the Serviio-Console application bundle.
I found /Library/Application Support/Serviio/log/serviio.log but there don't seem to be any entries in it related to the Console starting up.
I tried setting DEBUG in the log4j.xml file, in both the config directory and inside the Console application, but still didn't see anything from Console in the serviio.log file...
araCHnos
Post Thu Sep 24, 2015 3:42 pm
Hi There
Same problem here - starting time more than 10 Minutes and no log file available.
Attached three process anlaysis. First after start, the second 5 Minutes later and third again 5 minutes later. :o
Servvio Console 1.5.2 on OS X 10.10.5
*edit* this is running on a Mac Pro early 2008. Running on a iMac middle 2010 the problem does not exists :shock:
regards
Stephan
ProcessAnalysis_Serviio_1-3.zip
(68.31 KiB) Downloaded 474 times
sumguy
Post Tue Sep 29, 2015 10:48 am
Anything else I can do to help test this? Another place to look for the log?
Apart from that, everything seems to work ok, so it's useable. Just a bit of an annoyance.
Post Wed Sep 30, 2015 7:55 am
I'm not sure. It might be something to do with the network, as the console is trying to open a socket to make sure only one instance is running.
Alternatively
- live with it for now and wait for 1.6 which will have a web based console (still some time away from release)
- use remote console
- use the current third party web console
- use ServiiDroid, if you have Android device
