Serviio doesn't load the external subtitle
chibao
Post Sat Aug 29, 2015 10:16 am
I am using Sony Bravia KDL-43W800C and use Serviio as a media server.
Everything is good, but the external sub is not loaded and have few problem.
Here's what I try to load the sub.
The first time:
I tried this, Everything is good but there is no sub.
The second time:
When I tried this settings, on TV, this happened.
The sub is here, but the Total time of movie is showing as 00:00 and also we can't scroll, skip....
So how to solve this? I want to have sub but I also want they display the Total time and scrollable.
kampertuga
Post Sun Sep 13, 2015 7:43 pm
Re: Serviio doesn't load the external subtitle
I have a similar problem.
My TV is a Sony Bravia KD-49X8305C Android TV.
Without subtitles and with the Sony Bravia TV (2013/14) profile, the movie runs fine.
The moment i activate the "Enable burned-in subtitles" the TV only shows "Cannot play video".
I've tried the profile "Sony Bravia TV (2013)*" fix i found on the forum but with no luck as well.
I've tried the "Generic DLNA profile", it works great with subtitles on the TV however you cannot search the video (forward button moves the film at most at 1x)
and after 4 or so minutes it just loops back to the beginning.
What am i doing wrong?
What profile should I use for my TV?
ddasd
Post Thu Sep 24, 2015 11:52 pm
did u fix anything?
ddasd
Post Fri Sep 25, 2015 11:36 am
I have the same proble... Movie loop back arouns 1:45 min... Does anyone have solution?
Sent from my A0001 using Tapatalk
