Can't connect Serviio to Sony Blu ray player
flobiwan
Post Sun Sep 27, 2015 3:47 pm
Everything was working fine with Serviio connecting to my Sony Blu ray player. Then, i noticed that my internet connection was slow so i reset winsock and ipv6 because i noticed that ipv6 connectivity on my LAN is showing "no internet access". Ipv4 is fine. When i restarted my PC, the internet was a lot faster but now the blu ray player no longer recognizes serviio.
I cleared the server list on the blu ray player and refreshed. I also cleared the list oi devices in Serviio and refreshed. Serviio sees the blu ray player the player doesn't find Serviio. Can anyone help?
EDIT: I enabled Debug mode in order to get a log and, when i started Serviio, it showed up on the bluRay player! So, it looks like it's fine.
Post Mon Oct 05, 2015 12:26 pm
Re: Can't connect Serviio to Sony Blu ray player
flobiwan wrote:Everything was working fine with Serviio connecting to my Sony Blu ray player. Then, i noticed that my internet connection was slow so i reset winsock and ipv6 because i noticed that ipv6 connectivity on my LAN is showing "no internet access". Ipv4 is fine. When i restarted my PC, the internet was a lot faster but now the blu ray player no longer recognizes serviio.
There is a way to tell a Sony player to use IPv4 by default. You have to go into the network settings manually and tell it to, but you can still leave all the other settings on auto. However, since it now seems to be working OK, I'd just leave it alone.
