UE65HU7500 problem with h-profile (probably)
drMARTINS
Post Fri Sep 18, 2015 4:46 pm
i have some strange error.
When i first brig my new samsung tv UE65HU7500, console thought that tv is e/f series.
I changed it to H. Everything works great. After a few day it stopped work and tv shows me, when i try to play something from folder, (not from all folders) but usually from end folders, error that say Request cannot be completed. Media play will return to the main screen.
So i switched to Generic DLNA profile, everything worked fine, i could play everything, ofcource i had not advantages of H-series profile.
Again after few day i tried to switch back to h-series profile and again everything worked fine.
And of course again after few days same problem so now i have to be on Generic DLNA profile :-(
Another samsung tv UE55F6400 works wit e/f profile with no problems.
I have latest serviio 1.5.2 installed on Ubuntu server 14.04.3LTS, in TV is latest firmware.
Thank for any advice and help
Post Sat Sep 19, 2015 1:51 am
Re: UE65HU7500 problem with h-profile (probably)
I'm having a few issues with the H profile, but I'm using it on an JU set. One thing my TV will do sometimes is when I select a video it begins loading, then gives an error. If I select it again, it then loads and plays fine. I had the same issue when I had an HU8550 previously, so I'm guessing the problem is the Samsung firmware, and not Serviio. That's no help to you of course, other than letting you know you aren't alone with issues.
But, do try selecting the same video after you get the error and see if it will play.
drMARTINS
Post Sat Sep 19, 2015 12:32 pm
I don't undertand one thing. Why tv worked fine, and stop with no reason.
My problem is with folders not with files. When i am in some folder and there is some subfolder, files in this folder works, but when i click on subfolder then i get error.
I cannot find anything relevant in log of serviio.
Post Sat Sep 19, 2015 11:38 pm
Enable debug logging (don't leave it on a long time, logs get quite large). When you encounter the problem, save a copy of the log and post it here, if you can't see anything in it yourself.
drMARTINS
Post Thu Sep 24, 2015 4:45 pm
So i switch do debug, set for tv h-series profile and got this
192.168.88.135 is serviio server and 192.168.88.31 is TV. Unfortunately i don't undestatnd what is says to me :-(
2015-09-24 18:37:19,379 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth0-0
2015-09-24 18:37:19,380 INFO  [WebServer] WebServer starting on port 8895
2015-09-24 18:37:19,381 INFO  [Device] Updated bound IP address of Device with UUID: 01bd8c4a-8791-32ce-8f17-cad644a44245, bound address: 192.168.88.135
2015-09-24 18:37:19,407 DEBUG [DiscoveryManager] UPNP device 01bd8c4a-8791-32ce-8f17-cad644a44245 (192.168.88.135) is available
2015-09-24 18:37:19,409 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-09-24 18:37:19,412 INFO  [EventDispatcher] Starting EventDispatcher
2015-09-24 18:37:19,419 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-09-24 18:37:19,420 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-24 18:37:19,435 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2015-09-24 18:37:19,437 INFO  [RendererSearchSender] Searching for Renderer devices
2015-09-24 18:37:19,442 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-24 18:37:19,451 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-24 18:37:19,504 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2015-09-24 18:37:19,507 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-24 18:37:19,555 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.88.135:35358s
2015-09-24 18:37:19,558 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-24 18:37:19,560 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-24 18:37:19,563 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.88.135:35358s
2015-09-24 18:37:19,564 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-24 18:37:19,565 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-24 18:37:19,576 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.88.135:35358s
2015-09-24 18:37:19,584 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-24 18:37:19,585 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-24 18:37:19,669 DEBUG [RendererManager] Adding renderer Renderer [uuid=0e4e1c02-00f0-1000-b849-84a46603be3c, ipAddress=192.168.88.31, name=UE65HU7500, profileId=sam_h, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2015-09-24 18:37:20,155 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47158: GET /deviceDescription/01bd8c4a-8791-32ce-8f17-cad644a44245 HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-24 18:37:20,157 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:20,199 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 01bd8c4a-8791-32ce-8f17-cad644a44245 from 192.168.88.31 (headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50])
2015-09-24 18:37:20,200 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:20,203 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]
2015-09-24 18:37:20,207 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:21,254 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (H-series)'
2015-09-24 18:37:21,319 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-09-24 18:37:21,329 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47159: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-24 18:37:21,330 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:21,335 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2015-09-24 18:37:21,375 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-24 18:37:21,444 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47160: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-24 18:37:21,446 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:21,451 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2015-09-24 18:37:21,529 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-24 18:37:21,616 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47161: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-24 18:37:21,617 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:21,622 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2015-09-24 18:37:21,644 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-24 18:37:22,076 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47162: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-24 18:37:22,077 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:22,082 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-24 18:37:23,203 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-24 18:37:23,204 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-24 18:37:23,206 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-24 18:37:23,207 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-24 18:37:23,219 DEBUG [RendererManager] Adding renderer Renderer [uuid=b5f3cc09-334d-2eb4-ffff-ffffe14da80f, ipAddress=192.168.88.107, name=Rockchip Media Renderer, profileId=1, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2015-09-24 18:37:23,587 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-24 18:37:23,588 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-24 18:37:23,589 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-24 18:37:23,590 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-24 18:37:25,509 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2015-09-24 18:37:26,003 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47164: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-24 18:37:26,004 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:26,009 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-24 18:37:26,719 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47165: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-24 18:37:26,720 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:26,725 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-24 18:37:26,745 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47166: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-24 18:37:26,746 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:26,750 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-24 18:37:29,451 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-24 18:37:29,455 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-24 18:37:31,262 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-09-24 18:37:31,701 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:47168: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-24 18:37:31,702 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-24 18:37:31,708 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-24 18:37:39,453 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-24 18:37:39,457 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-24 18:37:41,264 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:03 (advertisement duration is 1800 sec.)
2015-09-24 18:37:42,311 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2015-09-24 18:37:42,312 INFO  [LibraryOneTimeScanner] Interrupting library scan
2015-09-24 18:37:42,313 DEBUG [LibraryOneTimeScanner] Library scan has been interrupted
2015-09-24 18:37:42,311 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2015-09-24 18:37:42,317 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2015-09-24 18:37:42,317 INFO  [PluginCompilerThread] Finished looking for plugins
2015-09-24 18:37:42,445 INFO  [SearchManager] Starting up search engine
2015-09-24 18:37:43,320 INFO  [SearchIndexer] Closing search index writer
2015-09-24 18:37:43,335 INFO  [SearchIndexer] Closing search index writer
2015-09-24 18:37:43,339 DEBUG [WebServer] Socket closed
2015-09-24 18:37:43,340 DEBUG [WebServer] Marking the web server for exit
2015-09-24 18:37:43,340 INFO  [WebServer] WebServer shutting down
2015-09-24 18:37:43,339 DEBUG [DiscoveryManager] UPNP device 01bd8c4a-8791-32ce-8f17-cad644a44245 (192.168.88.135) is unavailable
2015-09-24 18:37:43,342 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-09-24 18:37:43,343 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-09-24 18:37:43,344 INFO  [EventDispatcher] Leaving EventDispatcher
2015-09-24 18:37:43,344 DEBUG [DiscoverySSDPMessageListener] Socket closed: Socket closed
2015-09-24 18:37:43,345 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-09-24 18:37:43,346 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-24 18:37:43,350 INFO  [DatabaseManager] Shutting down database
2015-09-24 18:37:43,353 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2015-09-24 18:37:43,354 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2015-09-24 18:37:43,522 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2015-09-24 18:37:43,522 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-09-24 18:37:43,525 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: /data/Serviio
Post Sun Sep 27, 2015 11:03 pm
OK, this log only looks to be for about 30 seconds of operation, based on the time stamps. I see no errors in here. I do see the profile assigned correctly for your set.
Have you browsed any folders and attempted to play something? I see no play requests in there. I don't think the error is in these particular log entries. I know it means a lot more data, but I think you need to save for a longer time period.
drMARTINS
Post Mon Sep 28, 2015 7:48 am
well now i turn of serviio, delete everything from log, set debug a turn back on serviio. On tv i try 3 times to access to 3 different folder. Everytime same error. Here is log. Log is from turning serviio on to turning off after test. There is a lot of information so i have to split to 2 messages
2015-09-28 09:39:13,992 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2015-09-28 09:39:14,000 INFO  [MediaServer] ------------------------------------------------------------------------
2015-09-28 09:39:14,001 INFO  [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-09-28 09:39:14,001 INFO  [MediaServer] Petr Nejedly 2009-2015
2015-09-28 09:39:14,002 INFO  [MediaServer] http://www.serviio.org
2015-09-28 09:39:14,002 INFO  [MediaServer] Java 1.8.0_60-Oracle Corporation amd64
2015-09-28 09:39:14,003 INFO  [MediaServer] OS Linux 3.13.0-24-generic
2015-09-28 09:39:14,003 INFO  [MediaServer] File encoding: UTF-8
2015-09-28 09:39:14,342 INFO  [MediaServer] Headless mode enabled: true
2015-09-28 09:39:14,342 INFO  [MediaServer] User: root
2015-09-28 09:39:14,347 INFO  [MediaServer] User home dir: /root
2015-09-28 09:39:14,347 INFO  [MediaServer] Temp dir: /tmp
2015-09-28 09:39:14,347 INFO  [MediaServer] ------------------------------------------------------------------------
2015-09-28 09:39:14,368 DEBUG [MediaServer] Runtime params: -Xmx512M, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dderby.system.home=/opt/serviio/library, -Dserviio.home=/opt/serviio, -Dffmpeg.location=ffmpeg, -Ddcraw.location=dcraw
2015-09-28 09:39:15,138 INFO  [WebServer] Socket buffer set to 65535 bytes
2015-09-28 09:39:15,142 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-09-28 09:39:15,471 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-09-28 09:39:15,473 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-09-28 09:39:15,542 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-09-28 09:39:15,577 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2015-09-28 09:39:15,584 INFO  [DatabaseManager] Using DERBY database language
2015-09-28 09:39:17,670 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2015-09-28 09:39:20,225 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2015-09-28 09:39:20,230 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2015-09-28 09:39:20,235 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2015-09-28 09:39:20,237 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth0-0
2015-09-28 09:39:20,242 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2015-09-28 09:39:20,251 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2015-09-28 09:39:20,256 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2015-09-28 09:39:20,262 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2015-09-28 09:39:20,267 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2015-09-28 09:39:20,273 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2015-09-28 09:39:20,278 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2015-09-28 09:39:20,283 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2015-09-28 09:39:20,288 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2015-09-28 09:39:20,293 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2015-09-28 09:39:20,299 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2015-09-28 09:39:20,303 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2015-09-28 09:39:20,331 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2015-09-28 09:39:20,336 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2015-09-28 09:39:20,341 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2015-09-28 09:39:20,387 DEBUG [LicensingManager] Updating license
2015-09-28 09:39:20,388 DEBUG [LicenseValidator] Validating license file (370 bytes)
2015-09-28 09:39:20,561 INFO  [Device] Created UPnP Device with UUID: 01bd8c4a-8791-32ce-8f17-cad644a44245, bound address: 192.168.88.135
2015-09-28 09:39:20,886 INFO  [MediaServer] ------------------------------------------------------------------------
2015-09-28 09:39:20,887 INFO  [MediaServer] License: PRO (NORMAL, id: eab664d5-9c9f-4c2e-b7d9-9e3c4e0e1ec8)
2015-09-28 09:39:20,887 INFO  [MediaServer] ------------------------------------------------------------------------
2015-09-28 09:39:21,455 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.LinuxWatchService' for delta scan
2015-09-28 09:39:23,583 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2015-09-28 09:39:23,593 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2015-09-28 09:39:24,028 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-09-28 09:39:24,029 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2015-09-28 09:39:24,074 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-09-28 09:39:24,076 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2015-09-28 09:39:24,089 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-09-28 09:39:24,089 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2015-09-28 09:39:24,094 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-09-28 09:39:24,095 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2015-09-28 09:39:24,098 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-09-28 09:39:24,099 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2015-09-28 09:39:24,105 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-09-28 09:39:24,105 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2015-09-28 09:39:24,112 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-09-28 09:39:24,113 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2015-09-28 09:39:24,117 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-09-28 09:39:24,117 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2015-09-28 09:39:24,120 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-09-28 09:39:24,120 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2015-09-28 09:39:24,123 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-09-28 09:39:24,124 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2015-09-28 09:39:24,175 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-09-28 09:39:24,176 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2015-09-28 09:39:24,182 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-09-28 09:39:24,182 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2015-09-28 09:39:24,191 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-09-28 09:39:24,192 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2015-09-28 09:39:24,195 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-09-28 09:39:24,196 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2015-09-28 09:39:24,204 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-09-28 09:39:24,205 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2015-09-28 09:39:24,207 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-09-28 09:39:24,208 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2015-09-28 09:39:24,211 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-09-28 09:39:24,211 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2015-09-28 09:39:24,215 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-09-28 09:39:24,215 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2015-09-28 09:39:24,220 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-09-28 09:39:24,220 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2015-09-28 09:39:24,227 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-09-28 09:39:24,228 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2015-09-28 09:39:24,230 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-09-28 09:39:24,231 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2015-09-28 09:39:24,234 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-09-28 09:39:24,234 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2015-09-28 09:39:24,237 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-09-28 09:39:24,238 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2015-09-28 09:39:24,241 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-09-28 09:39:24,241 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2015-09-28 09:39:24,244 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-09-28 09:39:24,245 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2015-09-28 09:39:24,248 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-09-28 09:39:24,248 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2015-09-28 09:39:24,252 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-09-28 09:39:24,252 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2015-09-28 09:39:24,256 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-09-28 09:39:24,257 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2015-09-28 09:39:24,261 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-09-28 09:39:24,262 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2015-09-28 09:39:24,267 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-09-28 09:39:24,267 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2015-09-28 09:39:24,272 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-09-28 09:39:24,272 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2015-09-28 09:39:24,275 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-09-28 09:39:24,276 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2015-09-28 09:39:24,278 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-09-28 09:39:24,279 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2015-09-28 09:39:24,281 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-09-28 09:39:24,281 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2015-09-28 09:39:24,284 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-09-28 09:39:24,284 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2015-09-28 09:39:24,286 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-09-28 09:39:24,287 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2015-09-28 09:39:24,290 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-09-28 09:39:24,291 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2015-09-28 09:39:24,293 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-09-28 09:39:24,294 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2015-09-28 09:39:24,296 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-09-28 09:39:24,297 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2015-09-28 09:39:24,304 INFO  [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-09-28 09:39:24,304 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2015-09-28 09:39:24,308 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-09-28 09:39:24,309 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2015-09-28 09:39:24,311 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-09-28 09:39:24,312 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2015-09-28 09:39:24,314 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-09-28 09:39:24,315 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2015-09-28 09:39:24,322 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-09-28 09:39:24,323 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2015-09-28 09:39:24,325 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-09-28 09:39:24,326 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2015-09-28 09:39:24,329 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-09-28 09:39:24,330 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2015-09-28 09:39:24,333 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-09-28 09:39:24,334 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2015-09-28 09:39:24,338 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-09-28 09:39:24,582 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2015-09-28 09:39:24,583 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2015-09-28 09:39:24,590 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-09-28 09:39:24,590 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2015-09-28 09:39:24,593 INFO  [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-09-28 09:39:24,593 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2015-09-28 09:39:24,595 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-09-28 09:39:24,596 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2015-09-28 09:39:24,599 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-09-28 09:39:24,600 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2015-09-28 09:39:24,603 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-09-28 09:39:24,604 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2015-09-28 09:39:24,607 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-09-28 09:39:24,607 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2015-09-28 09:39:24,610 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-09-28 09:39:24,611 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2015-09-28 09:39:24,615 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-09-28 09:39:24,615 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2015-09-28 09:39:24,619 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-09-28 09:39:24,619 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2015-09-28 09:39:24,624 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-09-28 09:39:24,751 INFO  [PluginCompilerThread] Looking for plugins at /opt/serviio/plugins
2015-09-28 09:39:24,760 INFO  [PluginCompilerThread] Started looking for plugins
2015-09-28 09:39:24,768 INFO  [UpdateChecker] Checking if a new version is available
2015-09-28 09:39:24,815 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path ffmpeg
2015-09-28 09:39:24,832 DEBUG [ProcessExecutor] Starting ffmpeg
2015-09-28 09:39:25,444 INFO  [FFMPEGWrapper] Found FFmpeg: ffmpeg version 1.2.6-7:1.2.6-1~trusty1 Copyright (c) 2000-2014 the FFmpeg developers
2015-09-28 09:39:25,444 WARN  [FFMPEGWrapper] FFmpeg is not compiled with libass support, rendering subtitles (hardsubs) will not work.
2015-09-28 09:39:25,445 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = subtitles_hardsubs_enabled)
2015-09-28 09:39:25,500 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = subtitles_hardsubs_enabled, value = false)
2015-09-28 09:39:25,525 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-09-28 09:39:26,082 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path dcraw
2015-09-28 09:39:26,095 DEBUG [ProcessExecutor] Starting dcraw
2015-09-28 09:39:26,235 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-09-28 09:39:26,236 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: /data/Serviio
2015-09-28 09:39:26,248 DEBUG [RendererDAOImpl] Updating Renderer (uuid = 0e4e1c02-00f0-1000-b849-84a46603be3c, ipAddress = 192.168.88.31)
2015-09-28 09:39:26,465 INFO  [WebServer] WebServer starting on port 8895
2015-09-28 09:39:26,464 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth0-0
2015-09-28 09:39:26,473 INFO  [Device] Updated bound IP address of Device with UUID: 01bd8c4a-8791-32ce-8f17-cad644a44245, bound address: 192.168.88.135
2015-09-28 09:39:26,521 DEBUG [StatusServerResource] Storing bound NIC: eth0-0
2015-09-28 09:39:26,521 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = bound_nic_name)
2015-09-28 09:39:26,531 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = bound_nic_name, value = eth0-0)
2015-09-28 09:39:26,536 DEBUG [DiscoveryManager] UPNP device 01bd8c4a-8791-32ce-8f17-cad644a44245 (192.168.88.135) is available
2015-09-28 09:39:26,542 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = renderer_enabled_default)
2015-09-28 09:39:26,545 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = renderer_enabled_default, value = true)
2015-09-28 09:39:26,548 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-09-28 09:39:26,552 INFO  [EventDispatcher] Starting EventDispatcher
2015-09-28 09:39:26,554 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = renderer_default_access_group_id)
2015-09-28 09:39:26,557 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = renderer_default_access_group_id, value = 1)
2015-09-28 09:39:26,561 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-09-28 09:39:26,566 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2015-09-28 09:39:26,568 INFO  [RendererSearchSender] Searching for Renderer devices
2015-09-28 09:39:26,568 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:26,590 DEBUG [WebServer] Socket closed
2015-09-28 09:39:26,588 DEBUG [DiscoveryManager] UPNP device 01bd8c4a-8791-32ce-8f17-cad644a44245 (192.168.88.135) is unavailable
2015-09-28 09:39:26,591 DEBUG [WebServer] Marking the web server for exit
2015-09-28 09:39:26,591 INFO  [WebServer] WebServer shutting down
2015-09-28 09:39:26,591 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-09-28 09:39:26,600 INFO  [EventDispatcher] Leaving EventDispatcher
2015-09-28 09:39:26,600 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:26,598 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:26,597 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-09-28 09:39:26,596 DEBUG [DiscoverySSDPMessageListener] Socket closed: Socket closed
2015-09-28 09:39:26,605 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:26,615 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-09-28 09:39:26,602 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
2015-09-28 09:39:26,753 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-28 09:39:26,756 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2015-09-28 09:39:26,767 DEBUG [LocalAddressResolverStrategy] Resolving host IP address using stored bound NIC name: eth0-0
2015-09-28 09:39:26,768 INFO  [Device] Updated bound IP address of Device with UUID: 01bd8c4a-8791-32ce-8f17-cad644a44245, bound address: 192.168.88.135
2015-09-28 09:39:26,769 DEBUG [DiscoveryManager] UPNP device 01bd8c4a-8791-32ce-8f17-cad644a44245 (192.168.88.135) is available
2015-09-28 09:39:26,770 INFO  [WebServer] WebServer starting on port 8895
2015-09-28 09:39:26,772 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-09-28 09:39:26,774 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:26,775 INFO  [EventDispatcher] Starting EventDispatcher
2015-09-28 09:39:26,778 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-09-28 09:39:26,778 INFO  [RendererSearchSender] Searching for Renderer devices
2015-09-28 09:39:26,781 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:26,783 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2015-09-28 09:39:26,824 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.88.135:43053s
2015-09-28 09:39:26,830 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.88.135:43053s
2015-09-28 09:39:26,832 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.88.135:43053s
2015-09-28 09:39:26,834 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.88.168:59599s
2015-09-28 09:39:26,863 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:26,866 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-28 09:39:27,156 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,158 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-28 09:39:27,165 DEBUG [RendererManager] Adding renderer Renderer [uuid=0e4e1c02-00f0-1000-b849-84a46603be3c, ipAddress=192.168.88.31, name=UE65HU7500, profileId=sam_h, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2015-09-28 09:39:27,166 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.181:7676/smp_16_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,171 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0b532b80-00be-1000-9438-5085694bcb05 from address 192.168.88.181
2015-09-28 09:39:27,173 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,174 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-28 09:39:27,179 DEBUG [RendererManager] Adding renderer Renderer [uuid=0b532b80-00be-1000-9438-5085694bcb05, ipAddress=192.168.88.181, name=UE55F6400, profileId=sam_ef, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2015-09-28 09:39:27,184 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.181:7676/smp_16_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,185 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0b532b80-00be-1000-9438-5085694bcb05 from address 192.168.88.181
2015-09-28 09:39:27,191 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,192 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-28 09:39:27,207 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.181:7676/smp_16_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,209 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0b532b80-00be-1000-9438-5085694bcb05 from address 192.168.88.181
2015-09-28 09:39:27,216 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,217 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-28 09:39:27,229 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.181:7676/smp_16_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,229 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0b532b80-00be-1000-9438-5085694bcb05 from address 192.168.88.181
2015-09-28 09:39:27,234 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,235 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-28 09:39:27,253 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.181:7676/smp_16_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,254 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0b532b80-00be-1000-9438-5085694bcb05 from address 192.168.88.181
2015-09-28 09:39:27,255 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.31:7676/smp_11_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,258 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0e4e1c02-00f0-1000-b849-84a46603be3c from address 192.168.88.31
2015-09-28 09:39:27,276 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.181:7676/smp_16_, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:27,278 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer 0b532b80-00be-1000-9438-5085694bcb05 from address 192.168.88.181
2015-09-28 09:39:27,549 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59885: GET /deviceDescription/01bd8c4a-8791-32ce-8f17-cad644a44245 HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-28 09:39:27,551 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:27,597 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 01bd8c4a-8791-32ce-8f17-cad644a44245 from 192.168.88.31 (headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50])
2015-09-28 09:39:27,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:27,603 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]
2015-09-28 09:39:27,608 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:27,611 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36766: GET /deviceDescription/01bd8c4a-8791-32ce-8f17-cad644a44245 HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:27,614 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36767: GET /deviceDescription/01bd8c4a-8791-32ce-8f17-cad644a44245 HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:27,615 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:27,627 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:27,637 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 01bd8c4a-8791-32ce-8f17-cad644a44245 from 192.168.88.181 (headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50])
2015-09-28 09:39:27,639 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:27,650 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]
2015-09-28 09:39:27,661 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:27,674 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]
2015-09-28 09:39:27,678 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:28,151 DEBUG [ServiioHttpService] Incoming request from /192.168.88.204:55694: GET /deviceDescription/01bd8c4a-8791-32ce-8f17-cad644a44245 HTTP/1.1, headers = [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: DAFUPnP,Host: 192.168.88.135:8895]]
2015-09-28 09:39:28,156 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.204
2015-09-28 09:39:28,173 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 01bd8c4a-8791-32ce-8f17-cad644a44245 from 192.168.88.204 (headers = [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: DAFUPnP,Host: 192.168.88.135:8895])
2015-09-28 09:39:28,192 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.204
2015-09-28 09:39:28,197 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: DAFUPnP,Host: 192.168.88.135:8895]
2015-09-28 09:39:28,205 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.204
2015-09-28 09:39:28,591 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-09-28 09:39:28,699 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-09-28 09:39:28,751 DEBUG [ServiioHttpService] Incoming request from /192.168.88.204:55695: GET /deviceDescription/01bd8c4a-8791-32ce-8f17-cad644a44245 HTTP/1.1, headers = [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: DAFUPnP,Host: 192.168.88.135:8895]]
2015-09-28 09:39:28,753 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.204
2015-09-28 09:39:28,769 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 01bd8c4a-8791-32ce-8f17-cad644a44245 from 192.168.88.204 (headers = [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: DAFUPnP,Host: 192.168.88.135:8895])
2015-09-28 09:39:28,769 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.204
2015-09-28 09:39:28,802 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Cache-Control: no-cache,Connection: Keep-Alive,Pragma: no-cache,Accept: text/xml, application/xml,User-Agent: DAFUPnP,Host: 192.168.88.135:8895]
2015-09-28 09:39:28,809 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.204
2015-09-28 09:39:29,132 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-09-28 09:39:29,166 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (H-series)'
2015-09-28 09:39:29,168 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2015-09-28 09:39:29,170 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (E/F-series)'
2015-09-28 09:39:29,171 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Samsung TV / player (E/F-series)'
2015-09-28 09:39:29,247 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59886: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,248 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:29,262 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36768: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,263 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:29,278 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2015-09-28 09:39:29,279 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2015-09-28 09:39:29,339 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36769: GET /serviceDescription/ConnectionManager HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,340 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:29,343 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2015-09-28 09:39:29,395 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,400 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,401 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,468 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59887: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,469 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:29,480 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2015-09-28 09:39:29,530 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36771: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,531 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:29,539 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,541 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2015-09-28 09:39:29,542 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,545 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36770: GET /serviceDescription/ContentDirectory HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,546 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:29,555 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2015-09-28 09:39:29,557 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,630 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59888: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED65/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,630 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:29,631 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-28 09:39:29,632 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:29,632 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:29,633 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-28 09:39:29,634 DEBUG [RendererManager] Adding renderer Renderer [uuid=b5f3cc09-334d-2eb4-ffff-ffffe14da80f, ipAddress=192.168.88.107, name=Rockchip Media Renderer, profileId=1, manuallyAdded=false, forcedProfile=false, enabled=true, accessGroupId=1] to list of active renderers
2015-09-28 09:39:29,645 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2015-09-28 09:39:29,667 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,703 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36772: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,703 DEBUG [ServiioHttpService] Incoming request from /192.168.88.181:36773: GET /serviceDescription/X_MS_MediaReceiverRegistrar HTTP/1.1, headers = [HOST: 192.168.88.135:8895,ACCEPT-ENCODING: deflate,ACCEPT-LANGUAGE: en-us,User-Agent: SEC_HHP_[TV]Samsung LED55/1.0 DLNADOC/1.50]]
2015-09-28 09:39:29,703 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
drMARTINS
2015-09-28 09:39:29,704 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.181
2015-09-28 09:39:29,708 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2015-09-28 09:39:29,710 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2015-09-28 09:39:29,824 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.88.168:59599s
2015-09-28 09:39:31,499 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:31,500 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-28 09:39:31,501 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.88.107:38388/deviceDescription/MediaRenderer, st: urn:schemas-upnp-org:device:MediaRenderer:1
2015-09-28 09:39:31,502 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b5f3cc09-334d-2eb4-ffff-ffffe14da80f from address 192.168.88.107
2015-09-28 09:39:31,567 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2015-09-28 09:39:32,766 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2015-09-28 09:39:32,790 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2015-09-28 09:39:36,605 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:36,609 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-28 09:39:36,864 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:36,868 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-28 09:39:38,415 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-09-28 09:39:38,675 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-09-28 09:39:43,846 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59890: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:39:43,847 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:43,850 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:39:46,606 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:46,609 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-28 09:39:46,865 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:39:46,868 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 01bd8c4a-8791-32ce-8f17-cad644a44245
2015-09-28 09:39:48,101 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59891: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:39:48,103 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:48,107 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:39:48,416 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:06 (advertisement duration is 1800 sec.)
2015-09-28 09:39:48,675 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:33 (advertisement duration is 1800 sec.)
2015-09-28 09:39:48,787 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59892: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:39:48,788 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:48,790 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:39:48,801 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59893: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:39:48,802 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:39:48,804 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:39:52,783 INFO  [FeedUpdaterWorker] Started looking for information about online resources
2015-09-28 09:39:52,784 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-09-28 09:39:52,787 INFO  [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-09-28 09:39:52,801 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-09-28 09:39:53,033 DEBUG [LocalLibraryManager] Automatic update required: false
2015-09-28 09:39:53,033 DEBUG [LocalLibraryManager] Automatic updates enabled: false
2015-09-28 09:40:01,394 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59899: GET /resource/49821/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,395 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,404 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,434 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,440 DEBUG [ResourceDeliveryProcessor] Request for resource 49821 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,458 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49821)
2015-09-28 09:40:01,547 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49821 cannot be found
2015-09-28 09:40:01,555 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59900: GET /resource/40554/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,557 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,561 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,565 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,574 DEBUG [ResourceDeliveryProcessor] Request for resource 40554 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,574 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 40554)
2015-09-28 09:40:01,583 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 40554 cannot be found
2015-09-28 09:40:01,589 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59901: GET /resource/49823/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,591 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,600 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,608 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,610 DEBUG [ResourceDeliveryProcessor] Request for resource 49823 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,610 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49823)
2015-09-28 09:40:01,620 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49823 cannot be found
2015-09-28 09:40:01,628 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59902: GET /resource/49977/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,629 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,632 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,636 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,638 DEBUG [ResourceDeliveryProcessor] Request for resource 49977 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,639 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49977)
2015-09-28 09:40:01,643 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49977 cannot be found
2015-09-28 09:40:01,652 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59903: GET /resource/49820/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,653 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,657 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,660 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,661 DEBUG [ResourceDeliveryProcessor] Request for resource 49820 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,661 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49820)
2015-09-28 09:40:01,664 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49820 cannot be found
2015-09-28 09:40:01,670 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59904: GET /resource/49892/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,671 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,677 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,680 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,681 DEBUG [ResourceDeliveryProcessor] Request for resource 49892 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,681 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49892)
2015-09-28 09:40:01,684 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49892 cannot be found
2015-09-28 09:40:01,689 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59905: GET /resource/49889/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,689 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,693 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,697 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,698 DEBUG [ResourceDeliveryProcessor] Request for resource 49889 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,698 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49889)
2015-09-28 09:40:01,701 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49889 cannot be found
2015-09-28 09:40:01,707 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59906: GET /resource/49890/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,708 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,710 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,713 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,713 DEBUG [ResourceDeliveryProcessor] Request for resource 49890 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,714 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49890)
2015-09-28 09:40:01,716 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49890 cannot be found
2015-09-28 09:40:01,721 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59907: GET /resource/49893/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,722 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,725 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,728 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,729 DEBUG [ResourceDeliveryProcessor] Request for resource 49893 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,729 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49893)
2015-09-28 09:40:01,732 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49893 cannot be found
2015-09-28 09:40:01,748 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59908: GET /resource/49891/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,749 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,754 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,756 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,757 DEBUG [ResourceDeliveryProcessor] Request for resource 49891 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,757 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49891)
2015-09-28 09:40:01,760 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49891 cannot be found
2015-09-28 09:40:01,766 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59909: GET /resource/49852/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,767 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,770 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,773 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,774 DEBUG [ResourceDeliveryProcessor] Request for resource 49852 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,774 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49852)
2015-09-28 09:40:01,777 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49852 cannot be found
2015-09-28 09:40:01,785 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59910: GET /resource/40548/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,786 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,789 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,795 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,796 DEBUG [ResourceDeliveryProcessor] Request for resource 40548 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,796 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 40548)
2015-09-28 09:40:01,801 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 40548 cannot be found
2015-09-28 09:40:01,807 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59911: GET /resource/40321/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,808 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,811 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,814 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,815 DEBUG [ResourceDeliveryProcessor] Request for resource 40321 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,815 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 40321)
2015-09-28 09:40:01,818 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 40321 cannot be found
2015-09-28 09:40:01,824 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59912: GET /resource/49822/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:01,825 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,829 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:01,833 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.88.31, Profile=Samsung TV / player (H-series)'
2015-09-28 09:40:01,833 DEBUG [ResourceDeliveryProcessor] Request for resource 49822 and type 'COVER_IMAGE' received
2015-09-28 09:40:01,833 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 49822)
2015-09-28 09:40:01,836 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Cover image 49822 cannot be found
2015-09-28 09:40:11,711 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59915: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:11,712 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:11,715 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:11,728 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59916: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:11,729 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:11,732 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:14,698 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59918: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:14,698 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:14,701 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:16,005 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59921: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:16,005 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:16,008 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:29,160 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59923: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:29,161 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:29,163 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:31,205 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59925: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:31,206 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:31,208 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:32,490 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59927: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:32,490 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:32,492 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:32,509 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59928: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:32,510 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:32,513 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:40,816 DEBUG [ServiioHttpService] Incoming request from /192.168.88.31:59931: GET /icon/smallPNG HTTP/1.0, headers = [HOST: 192.168.88.135:8895,ACCEPT-LANGUAGE: en-us,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Interactive]]
2015-09-28 09:40:40,816 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.88.31
2015-09-28 09:40:40,819 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2015-09-28 09:40:40,861 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.88.196:62290s
2015-09-28 09:40:40,862 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.88.196:62290s
2015-09-28 09:40:40,863 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.88.196:62291s
2015-09-28 09:40:40,864 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.88.196:62291s
2015-09-28 09:40:52,998 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-09-28 09:40:52,999 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-09-28 09:41:06,476 INFO  [LibraryOneTimeScanner] Interrupting library scan
2015-09-28 09:41:06,477 DEBUG [LibraryOneTimeScanner] Library scan has been interrupted
2015-09-28 09:41:06,478 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2015-09-28 09:41:06,486 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2015-09-28 09:41:06,486 INFO  [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2015-09-28 09:41:06,483 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2015-09-28 09:41:06,500 INFO  [FeedUpdaterWorker] Finished looking for online resources information
2015-09-28 09:41:06,590 INFO  [PluginCompilerThread] Finished looking for plugins
2015-09-28 09:41:06,711 INFO  [SearchManager] Starting up search engine
2015-09-28 09:41:07,589 INFO  [SearchIndexer] Closing search index writer
2015-09-28 09:41:07,596 INFO  [SearchIndexer] Closing search index writer
2015-09-28 09:41:07,599 DEBUG [DiscoveryManager] UPNP device 01bd8c4a-8791-32ce-8f17-cad644a44245 (192.168.88.135) is unavailable
2015-09-28 09:41:07,599 DEBUG [WebServer] Socket closed
2015-09-28 09:41:07,599 DEBUG [WebServer] Marking the web server for exit
2015-09-28 09:41:07,600 INFO  [WebServer] WebServer shutting down
2015-09-28 09:41:07,600 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-09-28 09:41:07,600 INFO  [EventDispatcher] Leaving EventDispatcher
2015-09-28 09:41:07,601 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-09-28 09:41:07,602 DEBUG [DiscoverySSDPMessageListener] Socket closed: Socket closed
2015-09-28 09:41:07,603 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-09-28 09:41:07,604 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface eth0 (eth0) and address 192.168.88.135, timeout = 0
2015-09-28 09:41:07,607 INFO  [DatabaseManager] Shutting down database
2015-09-28 09:41:07,609 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2015-09-28 09:41:07,610 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2015-09-28 09:41:07,836 DEBUG [DatabaseManager] DB shutdown returned: Derby system shutdown.
2015-09-28 09:41:07,836 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-09-28 09:41:07,838 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: /data/Serviio
Post Mon Sep 28, 2015 12:34 pm
Re: UE65HU7500 problem with h-profile (probably)
I'm getting on a plane to England tomorrow, and won't be home until Sunday. It will be a while before I can look hard at this. Hopefully someone else will look it over and spot something.
drMARTINS
Post Wed Sep 30, 2015 6:19 pm
good news.
Today i installed new samsung firmware to my TV and now h profile works well. I hope that this situation will be permanent. :-)
Post Mon Oct 05, 2015 12:23 pm
drMARTINS wrote:good news.
What's the firmware version? I got home from England late Saturday night, and I checked for updates last night but it still shows me on the same version. I realize yours is the HU series and mine is the JU series (completely different OS), but I'm just wondering.
drMARTINS
Post Mon Oct 05, 2015 4:17 pm
New firmware is 1040
drMARTINS
Post Wed Oct 07, 2015 4:12 pm
And again it is not work :-( so same situation as before :-(
drMARTINS
Post Wed Oct 07, 2015 4:55 pm
I think i found solution.
I completly reinstall serviio. Change some folders. But i think this is not what was needed. Because when i tried to play something from serviio, i saw that everything is same as before. So i think that TV has to have some fuc**** cache which caused this problem. Ofcourse i don't know how it works but after i reset my TV (turn tv on by tv button and hold button EXIT on remote control for 12 second) everything in serviio update and works now again.
Maybe it is not full solution but it is good workaround how to solve this problem in future.
Maybe this help somebody too.
Post Wed Oct 07, 2015 5:50 pm
drMARTINS wrote:I think i found solution.
I noticed that my Samsung BluRay player would not refresh my Serviio folders, and I often had to power off and back on to force a refresh. You could be correct about some sort of internal cache. Certainly annoying, when my Sony will refresh a folder as soon as I leave and reenter it. Glad you found something that makes it somewhat satisfactory.
