Serviio Shows "no item"
Laz Baz
Post Sat Sep 19, 2015 1:49 pm
Laptop with Music files and Serviio server when connected directly to Onkyo TX-NR609 by Ethernet, Serviio shows "no item". Hoever, when laptop is on WiFi, Serviio does open all the files on laptop.
Can someone help please as I do not understand this.
Samsung UE55JU7000; Panasonic BDT 110; Cambridge Audio 640; IMF TLS80 Mk II front & Yamaha centre & surround speakers
Post Sun Sep 20, 2015 12:01 am
Re: Serviio Shows "no item"
Laz Baz wrote:Laptop with Music files and Serviio server when connected directly to Onkyo TX-NR609 by Ethernet, Serviio shows "no item". Hoever, when laptop is on WiFi, Serviio does open all the files on laptop.
When you connect via Ethernet, your computer gets a different IP address than the one assigned via Wi-Fi. Go to the Serviio Console. On the Status tab at the bottom, there's a box labeled Network Settings. It probably says Automatically Detected. Change it to the proper setting, then click the Save button on the lower right corner.
The Auto setting only works for when the computer is booted up on a network. If you change networks after Serviio is running, it won't recognize the change and is no longer connected to the proper network card in your computer. If you change from wired to Wi-Fi without rebooting or restarting the Serviio Service, you have to make this change. It's possible that the new address doesn't even show if you switch network connections without stopping the Serviio Service, so it may be necessary anyway.
Laz Baz
Post Mon Sep 21, 2015 12:32 am
Thank you DLNA master.
On my Onkyo DLNA device DHCP is enabled and IP address is 192.168.0.7; sub mask 255.255.255.0; Gateway 192.168.0.1; DSN server 194.168.4.100.
Serviio Status tab shows at the bottom; Enable access for new devices and this is ticked. Next to it is Default access group and this is greyed out.
Next one Network settings has two options to select from the drop down menu; (1) automatically detected and (2) 192.168.0.5 (Atheros AR9285 wireless network adaptor) and this cannot be edited. So how do I "Change it to the proper setting, then click the Save button on the lower right corner" as you suggest?
Some more guidance please.
Regards
Post Mon Sep 21, 2015 12:55 pm
Laz Baz wrote:Thank you DLNA master.
Regards
Yep, there's the problem. :D
Exit the Serviio console. To completely close it, right click the Serviio icon in the Notification Area (Windows) and select exit console (going by memory here). Now restart the console. This should update the Network Settings box to the currently active network adapter.
If it doesn't, exit the console again, then restart the Serviio service. Assuming you are running Windows, click the Start button and type Services. This will find the services app. Open it, find Serviio in the list, click it, then click restart on the list in the left window. When that finishes, reopen the Serviio console and the correct IP address should be listed.
If you are using something besides Windows, someone else will have to tell you how to restart the service. Rebooting will also accomplish this.
Laz Baz
Post Mon Sep 28, 2015 11:50 pm
Regards
Thank you again. I stopped and restarted Serviio and on the status tab the IP address of the Onkyo is listed 192.168.137.107, which shows on the Onkyo network menu as well. But when I select Serviio on Onkyo, it comes up with "No item".
What should I do next?
regards
Post Mon Oct 05, 2015 12:45 pm
Sorry for the delayed response. I was in England all last week.
Your network addresses have jumped for some reason. Before your addresses were 192.168.0.x, and now the Onkyo is using 192.168.137.x. Everything on your network must be within the same subnet. With normal home networks, this means that the first three numbers must be the same. Only the last digit changes, with .1 usually used by your router/Internet gateway.
What is assigning your IP addresses on your network? Usually it is a router/DSL or cable Modem. Find out what its settings are for the DHCP server. Sounds like something was altered somehow and it has changed its DHCP settings. When that happens, everything on the network must refresh its DHCP IP settings. Usually that means power cycling each device, although some devices keep their network connection active even when turned off. That means you may need to pull the power plug from each one for about 30 seconds, then plug it back in.
Laz Baz
Post Mon Oct 05, 2015 10:05 pm
atc98092 wrote:Sorry for the delayed response. I was in England all last week.
I live in England and our summer is gone!
Connecting the laptop to Onkyo receiver and re-setting all now shows all folder/subfolder/music files and plays without any audio drop-outs. Thank you.
However when the laptop is on WiFi only, there is audio drop-out. Perhaps you can point me in the right direction as to where I should concentrate as keeping the laptop connected to the receiver is very inconvenient.
Kind regards
William
Post Mon Oct 05, 2015 11:37 pm
Kind regards
William
It was quite nice in London and Cambridge. Just dropping my daughter off at Cambridge as she begins her Masters and Doctorate studies :D
If you are getting dropouts on Wi-Fi, but not when wired, then it's a simple issue of network speed. Your only option is to either increase your Wi-Fi speed (replacing the router if it doesn't support 802.11N or better and adding a faster external Wi-Fi card to the laptop if it doesn't support .11N or higher), or reduce the bitrate of what Serviio is streaming. Since reducing bitrate will potentially lower quality, that's perhaps not the best way to go, however.
Is there some reason you can't leave the laptop wired while using Serviio? If you must continue to use the laptop, consider finding an older computer that you can dedicate to just being your Serviio server. I have no clue what a used PC might cost there, but I'd be surprised if you couldn't get something reasonably nice for a couple hundred pounds or so. Of course, I have no idea what your finances are, so please don't take offence in the suggestion. Perhaps you have a friend that has an old cast off computer just sitting in a closet. It doesn't really take a lot of computer power to run Serviio, especially if no transcoding is required.
Laz Baz
Post Thu Oct 08, 2015 6:34 pm
Kind regards
William
No offence in any of the advise given. I am very thankful. It is inconvenient to to have my laptop connected to the receiver as the receiver is in the sitting room and generally the laptop in my man-cave. I could connect the laptop in the man-cave to a TP-Link adapter TL-PA451(500Mbps) plugged into the electric socket. Since the broadband router is connected to TP-Link
TL-PA211(200Mbps) and receiver to TL-PA251(200Mbps), would this method constitute a "direct connection" to the receiver or does it become a wireless system?
If you could briefly comment on this I may be able to understand and move on to other avenues as you have suggested if this does not work.
Kind regards
William
Post Thu Oct 08, 2015 6:58 pm
If I looked up the right information, this should all be considered a wired connection. It all depends on exactly how the laptop itself is connected. If you have an Ethernet cable connected to the laptop, even if a link further down the line is wireless, your router will assign the IP address to the laptop as if the cable was plugged directly into it. The router assigns the IP address based on the computer's MAC address. Since the wireless and wired connections on the laptop have different MAC addresses, that's why you get different IP addresses.
Even if your thoughtput was half the lowest rating (say 100Mbps, although that lower than I'd expect), that should be more than sufficient for your streaming. The highest bitrate I've measured was on a Blu-Ray rip that was hitting over 60Mbps. Most are in the 35-40Mbps range.
Users browsing this forum: Baidu [Spider], Google [Bot] and 60 guests
