Onkyo 607 TOSLINK 6 channel AAC to DD or DTS
jameslost
Post Sat Oct 10, 2015 1:37 pm
Was looking on the forum for an awnser, but can anyone point me to the right direction?
Seems all AAC 6 channel is send to PCM2.0.
Using panasonic tx50-cx800, onkyo 607 via toslink.
Thank you!
Optical connector (sometimes called TOSLINK)
This connection has limited bandwidth and can only supply
Dolby Digital (Bitstream)
DTS (Bitstream)
PCM (2 channel stereo)
Audio #1
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 49mn
Bit rate mode : Variable
Bit rate : 640 Kbps
Maximum bit rate : 655 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 500 MiB (17%)
Title : TuGAZx Audio 5.1 Surround
Language : English
Encoded date : UTC 2014-11-11 20:28:13
Tagged date : UTC 2014-11-11 21:33:37
Post Sat Oct 10, 2015 5:17 pm
Re: Onkyo 607 TOSLINK 6 channel AAC to DD or DTS
What profile are you using? What types of media files? Container and audio codecs? Once we know that, we can look at changes to the profile, or suggest a different profile.
jameslost
Post Sat Oct 10, 2015 7:19 pm
I'm using panasonic 2013 config, video file format .mp4
I got this info from mediacenter classic:
Video: MPEG4 Video (H264) 1920x816 23.976fps 1964kbps [V: h264 high L4.1, yuv420p, 1920x816, 1964 kb/s]
Audio: AAC 48000Hz 6ch 377kbps [A: English [eng] (aac lc, 48000 Hz, 5.1, 377 kb/s)]
Based on the info above i added
<Matches container="mp4" vCodec="h264" aCodec="aac" />
under
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
Is that the correct way? Onkyo says DD now instead of PCM.
Post Sun Oct 11, 2015 8:44 pm
Yep, I think you added it correctly. If the AVR now shows DD, then I'd say success!
