Files with extension M2V
NIckelino
Post Sat Oct 17, 2015 11:34 pm
Good evening,
I have a lot of MPEG-2 files with extension m2v in my private video library.
Is there any option to add them to the file library of Serviio and to make them playable through UPNP?
If not do anybody know a simple converter to make them playable with Serviio?
Greetings
Nicke
bu2d
Post Sun Oct 18, 2015 1:00 pm
Re: Files with extension M2V
I am not sure about adding them for upnp but if you want to convert them handbrake is free and works very well. I converted my library to .mp4 since it seems to be compatible with almost everything.
Post Sun Oct 18, 2015 10:12 pm
uPnP has nothing to do with playing them. Serviio uses the DLNA standard. uPnP is a networking protocol. :D
I agree that conversion to MP3 would be most beneficial, as virtually everything can play them without transcoding. As far as how to do it, there should be hundreds of programs available for that. Handbrake can do it of course, as can FFMPEG from the command line. Someone could likely even offer a script to automate the entire thing, but I'm not familiar enough with FFMPEG to do it.
I just entered "convert m2v to mp3" into Google and came back with 430,000 returns. Find something for free and give it a try. Just watch for them wanting to install something you don't want. Often freeware includes "optional" software that is selected by default. :x
jk50
Post Sun Oct 18, 2015 11:11 pm
Before you start re-encoding things , try changing the extension from .m2v to .mpg . I think Serviio will find it. The name change won't damage
your file, you can always change it back.
NIckelino
Post Mon Oct 19, 2015 8:33 pm
Hello People, thanks for you rreplies.
I just want to say OMG, renaming the files worked very well :lol:
I'm a specialist in information technique and sometimes I think in many complikated ways.
And sorry for my mistake to say UPNP instead of DLNA.... Evertime I say UPNP everyone knows what mean.
In case of this.
Thank you
Good night, good fight! 8-)
Post Wed Oct 21, 2015 12:48 am
Excellent, thanks for the update! :D
Users browsing this forum: Baidu [Spider] and 40 guests
