no subs
herman
Post Wed Jun 03, 2015 7:33 pm
no subs
Have a new Samsung TV ver. UE48J5515AK and now no subs are working. Non of my .srt files are working on the TV. I was all good on the old one.
One folder my have this:
Movite.mkv
Sub.srt
Post Wed Jun 03, 2015 11:46 pm
Re: no subs
Obvious question, but have to ask: the movie file and srt file are named identically, right? And you have subtitles enabled in the Serviio console?
Like I said, just the simple questions that have to be asked first, just to be sure.
Post Fri Jun 05, 2015 3:53 pm
Re: no subs
And make sure the Samsung profile is used.
herman
Post Tue Jun 09, 2015 8:38 am
Re: no subs
Yes, the files are namned the same and are in the same folder. As I said before, everything works fine on my old Samsung television but now it does not work with the text. I have tested all profiles for Samsung, find no profile for my (UE48J5515AK). Has completely run out of ideas here and therefore I thought seek an answer here.
Jamiroquai
Post Wed Jun 24, 2015 5:12 pm
Re: no subs
I have the same problem. On Samsung UE22F5400 (two years old model running Android - 2013) subtitles operate without problems. On the new Samsung television UE32J5672 (OS Tizen - 2015) only work subtitles in the mkv. Subtitles srt, sub, etc. are not working. I tried play movies via USB and all format subtitles function. I suppose the problem on the route from Serviio. Please add support for new models of Samsung.
ppsinoz
Post Thu Jun 25, 2015 7:16 am
Re: no subs
Same issue. My TV is a ua55j6200awxxy ... im using the profile Samsung H Series which i think it would be the closest to J series.
Will try to update my TV software and also enable burned-in subs... if it works, ill post it here ;).
jd_stojanov
Post Sat Jul 18, 2015 9:13 am
Re: no subs
Hi ,
I have the same problem with my J series Samsung (UE40J6300). The TV recognizes all my video files, including MKV, but would not load subtitles. Since there is no J profile in Serviio I have used the one for the H series. Anyone found a solution to this yet?
squadjot
Post Mon Aug 24, 2015 12:19 am
Re: no subs
Same problem. J5500 2015 running Tizen
zknafein
Post Thu Oct 01, 2015 1:10 pm
Re: no subs
Same problem on samsung UE43J5500. I think that samsung J-Series need a profile or something. Anybody knows how to fix it?
silvan
Post Sun Oct 11, 2015 10:05 pm
Re: no subs
Same problem UE48JS8500. No subs. I am using BubbleUPnP to get subtitles on TV.
roundup
Post Wed Oct 14, 2015 5:06 pm
Re: no subs
Same problem too on UE55JS9000
flaksy
Post Sat Oct 17, 2015 12:52 pm
Re: no subs
Same problem here. External subtitles won´t load on the 2015 model. Tested on avi, mkv, mp4 video files with srt subtitles. Names of the files are identical.
I used serviio 1.4.0 with Samsung UE32EH5300, samsung E/F series profile. It worked like a charm. I replaced the TV with Samsung UE48J6272 model, updated serviio to 1.5.2 version which lacks J profile, so I set up H profile, but subtitles won't load. So I guess it's a 2015 J series problem. Please fix servio asap, i love the app, used it for many years and I want to keep on using it. Thank you :)
Aaru Bui
Post Sun Oct 18, 2015 10:44 am
Re: no subs
Has every single Serviio profile been tried with the J-series?
Sent from my iPad using Tapatalk
aravorn
Post Sun Oct 25, 2015 5:06 pm
Re: no subs
zip wrote:And make sure the Samsung profile is used.
no profile is available for samsung J series :-(
ConflictCZ
Post Sun Oct 25, 2015 6:27 pm
Re: no subs
Should I upload here some log-file from playing movie with external .srt(.sub) subtitles, maybe someone from Serviio staff should find out problem with subtitles on J series...
keys
Post Fri Oct 30, 2015 12:33 am
Re: no subs
Same problem on UE48JU7500. No subs.
Also no 4k stream
Users browsing this forum: Baidu [Spider] and 21 guests
