Can't run version >1.4.1 on Linux Mint
nkostaki
Post Sat Oct 17, 2015 6:19 pm
This is very weird (or I'm very stupid in a way I can't yet see).
Iǘe been running Serviio on a pc running Linux Mint for over 3 years. Mint has gone from 13 to 14, 16, and now a clean install of 17.2. Seviio went back to 1.1 with upgrades bringing it to 1.4.1.
And there begins my problem. Whenever I tried to install a later Serviio version (1.4.1.2, 1.5, 1.5.2) and I try to run the serviio.sh file (and then the serviio-console.sh nothing happens). No action, no process shows in System Monitor. I then go into the Servio 1.4.1 folder, double-click on serviio.sh there and the server starts running, the 1.4.1 Serviio console starts normally (or gives the error "server not running" if I try to run it before the serviio.sh command). I've looked at the file properties and permissions for the two different version files and they are the same.
Please help.
Thank you,
Nikolas
Post Mon Oct 19, 2015 9:52 pm
Re: Can't run version >1.4.1 on Linux Mint
perhaps there is no java 8 installed
nkostaki
Post Sun Oct 25, 2015 10:25 am
THANK you zip, you are right!
I'll write what I did next to fix this just in case it can help some other newbie who stumbles upon the same problem.
To begin with, I typed "java -version" in Terminal and got
" java version "1.7.0_79"
OpenJDK Runtime Environment (IcedTea 2.5.6) (7u79-2.5.6-0ubuntu1.14.04.1)"
By Googling 'get Java8 on Mint 17' (and one failed attempt later in trying to follow Oracle Javaś instructions) I came upon the Serviio wiki (duh, I know), at http://wiki.serviio.org/doku.php?id=how ... all:ubuntu
After I entered the following commands in a Terminal window
sudo add-apt-repository ppa:webupd8team/java
sudo apt-get update
sudo apt-get install oracle-java8-installer
and accepting to Continue when asked, I typed "java -version" in Terminal and got
java version "1.8.0_66"
Java(TM) SE Runtime Environment (build 1.8.0_66-b17)
Now Serviio Server starts and the console loads!!
Users browsing this forum: Baidu [Spider] and 24 guests
