Serviio 1.5.2 - OS X 10.11.1 El Capitan
Neonwriter
Post Sun Oct 25, 2015 1:23 am
Headaches w/ recent OSX update(s).
Serviio no longer keeps computer awake while active. System will sleep unless it is set to "Never" in "Energy Saver" System Preference. Wasn't this way in the past, pre-El Capitan.
Often server will not start up properly with system restart. But, sometimes it will. ?
Any suggestions for these two issues much appreciated.
flipty
Post Sun Nov 01, 2015 4:02 am
Re: Serviio 1.5.2 - OS X 10.11.1 El Capitan
After my El Capitan upgrade I can only use Recently Added and Folders. All metadata is gone, and I don't know how to get it back.
flipty
Post Sun Nov 22, 2015 3:14 am
any word on this from anyone? Ever since El Capitan upgrade, no meta data at all comes through Serviio.
Post Mon Nov 23, 2015 10:16 am
check the detailed log. Click on Refresh video metadata on the metadata tab and then Force refresh on the Status tab.
daisyraven
Post Sun Jan 17, 2016 1:12 pm
Neonwriter wrote:Headaches w/ recent OSX update(s).
Same issue here on 10.11.2, shutdown is only solution that works to start serviio.
