Alaska99
Post Wed Oct 14, 2015 12:57 am
Re: PACKAGE: Serviio 1.4.1.2 - Synology NAS (ARMv5&v7 PPC In
No serviio 1.5.2 near to be released and now 1.4.1.2 is no more compatible with the new DSM 6.0 beta... It's so sad to see this lack of support. :cry:
Synology DS1512+ with DSM 6.0 beta 3gig ram | Blueray Sony BDP-S390 firmware M11.R.0422 | Blueray Sony BDP-BX58 | PS3 with latest firmware | Router Asus RT-AC68U Merlin firmware | Samsung TV UN65HU9000
mysteray
Post Wed Oct 14, 2015 9:13 am
Alaska99 wrote:No serviio 1.5.2 near to be released and now 1.4.1.2 is no more compatible with the new DSM 6.0 beta... It's so sad to see this lack of support. :cry:
Real pitty. I agree. Servioo has been a great DLNA server for me, but it's high time I moved on.
Fleetship1
Post Mon Oct 26, 2015 9:23 pm
Agree 100%. :-(
DS212j | Samsung UE40ES7090 | Sony BDP-S480 | modded xecuter Xbox 1
patters
Post Thu Nov 12, 2015 1:00 am
Who said 1.5.2 is not near to being released?
norm
Post Thu Nov 12, 2015 7:42 am
Re: PACKAGE: Serviio 1.5.2 - Synology NAS, with HW transcodi
patters wrote:Who said 1.5.2 is not near to being released?
Well done patters! 6 architectures sounds a hell of a job! Hopefully everyone appreciates your work.
Sent from my HTC One M9 using Tapatalk
adi82
Post Sun Nov 15, 2015 1:42 am
hi
just updated serviio 1.4.1.2 to 1.5.2 and I have a problem with adding video files
2015-11-15 02:36:06,245 INFO  [PlaylistMaintainerWorker] Started looking for playlist changes
2015-11-15 02:36:06,402 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/volume1/DLNA/igulka.avi). Message: Unknown video file type.
michal
Post Sun Nov 15, 2015 12:17 pm
After the last update on my DS1512+ with DSM5.2 to 1.5.2-0027, Serviio does not start anymore. The log shows:
2015-11-15 13:06:39,000 Starting Serviio
Exception in thread "main" java.lang.UnsupportedClassVersionError: org/serviio/MediaServer : Unsupported major.minor version 52.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:800)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
It used to work for few years like charm till today.
salut135
Post Sun Nov 15, 2015 1:47 pm
adi82 wrote:hi
Same. Not indexed video files. How to return the previous version 1.4?
adi82
Post Sun Nov 15, 2015 1:57 pm
salut135
Post Sun Nov 15, 2015 3:46 pm
adi82 wrote:I fixed my problem
thanks woodrook
http://forum.serviio.org/viewtopic.php?f=14&t=21028
Thank you for help!
patters
Post Tue Nov 17, 2015 3:21 am
I fixed this issue. I had compiled FFmpeg with arch=atom which I thought meant that no chip older than an Atom could run the binary. Recompiling without that option fixed the issue on Core i3 systems.
TheNemic
Post Fri Nov 20, 2015 8:57 pm
I also have this problem after update :( please help me, with fixing the problem :)
michal wrote:After the last update on my DS1512+ with DSM5.2 to 1.5.2-0027, Serviio does not start anymore. The log shows:
| Samsung UE40D5005 LED | DreamBox 800HD se | Windows 7 | Synology DS1515+ NAS |
Post Fri Nov 20, 2015 10:55 pm
You need Java 8 ^^^
patters
Post Sat Nov 21, 2015 12:51 am
My fault - the package was supposed to ensure Java 8 was present at install time but there was a bug there. Fixed now though.
RTH
Post Tue Nov 24, 2015 12:02 pm
Hello to all,
i have the same Problem with the new Version 1.5.2-0027 on Synology DS214Play, Java Embedded ejdk-8u65-linux-i586 1.8.0_65-0035.
All Plugins are installed.
I switched from version 1.4.1 to version 1.5.2, then having installed Java Embedded 8, as described in the manual, all Live Stream, RSS and Web Resources to see TV from Synology, did not work even one more, which with old version of Serviio worked. What works only, are some channels Live Stream Radio, and many others do not work more.
2015-11-24 12:34:33,760 WARN [FeedUpdaterWorker] Failed to retrieve Online Item information for [rtmp://link XXXX or http://XXXXXXX.xxxxx.xxxx], It might to play.
java.io.IOException: org.serviio.library.local.metadata.extractor.InvalidmediaFormatException: unknow video file type.
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:324)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:243)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:122)
Caused by: org.serviio.library.online.local.metadata.extractor.InvalidMediaFormatException: unknow video file type.
   org.serviio.library.online.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:467)
   org.serviio.library.online.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
   org.serviio.library.online.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
   org.serviio.library.online.metadata.FFmpegMetadataRetriever.retrieveMetadata(FeedUpdaterWorker.java:303)
        ...3 more
I have what I could Updated Plugins, but there is nothing to do.
Some radio work, many not, Live Stream or RSS nobody does.
Version 1.4.1 was very functional, and I also paid for the Pro Version.
CPU 32%
Ram 77%
letron
Post Tue Nov 24, 2015 1:54 pm
I'm trying to install serviio on my Synology DS415+ but without success because the package http://packages.pcloadletter.co.uk/down ... _64.tar.xz cannot be downloaded. See the snapshot in the attachment.
Thanks for help
serviio.tiff
serviio.tiff (78.52 KiB) Viewed 37294 times
patters
Post Wed Nov 25, 2015 7:43 pm
Sorry, my mistake. That issue is fixed now.
weedhopper
Post Wed Dec 02, 2015 12:46 pm
Hello
Where can we download Serviio Package ?
I have tried and following msg appair :
Not Found
The requested URL /downloads/serviio1.5-native-x86_64.tar.xz was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Thanx in advance
Regards
patters
Post Sat Dec 12, 2015 1:21 pm
Which model of NAS please, and which version of DSM?
dan010
Post Sun Dec 27, 2015 4:36 pm
Hi, I installed Java 1.9.0_65-0035 on my Synology NAS DS213 with DSM 5.2-5644 Update 1 and the Java is running!
But when I try to start the serviio 1.5.2-0027, it does not start and in protocol stays this:
2015-12-27 15:08:18,000 Starting Serviio
/var/ packages/ Serviio/ target/bin/serviio.sh: exec: line 67: /volume 1/@appstore/java8/ ejdk1.8.0_65/ linux_armv6_ vfp_ hflt/jre/ bin/java: not found
2015-12-27 15:08:50,000 Starting Serviio
2015-12-27 15:09:19,000 Starting Serviio
2015-12-27 15:09:42,000 Starting Serviio
2015-12-27 15:21:25,000 Starting Serviio
2015-12-27 15:22:54,000 Starting Serviio
2015-12-27 15:26:10,000 Starting Serviio
What is the problem?
