SeasonVar.ru (Web Resource)
PervySage
Post Sat Sep 19, 2015 4:14 am
Re: SeasonVar.ru (Web Resource)
I just noticed then, that it appears that the site has different links to what it did a few months ago.
Iternity Season 4 in a previous post had the link: http://seasonvar.ru/serial-10511-Interny-4-season.html
Now it has the link: http://seasonvar.ru/serial-10512-Interny-4-season.html
maxway123
Post Fri Sep 25, 2015 1:49 pm
2015-09-25 21:46:30,578 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-10512-Interny-4-season.html, will try again soon: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
org.serviio.library.online.metadata.OnlineResourceParseException: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:78)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:186)
at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:203)
at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:191)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:108)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at SeasonVar.getSourceFromPlayer(SeasonVar.groovy:108)
at SeasonVar.extractItems(SeasonVar.groovy:56)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
... 1 more
ivanoff999
Post Tue Oct 06, 2015 6:07 pm
SeasonVar.groovy v.8 doesn't works from Oct 6 th, 2015? Why
See serviio.log
2015-10-06 21:03:29,025 WARN [FeedUpdaterWorker] An error occured while parsing the online resource http://seasonvar.ru/serial-1537-Fejri-1-season.html, waiting for expiry time to try again: Unexpected error while invoking plugin (SeasonVar): index is out of range 0..-1 (index = 0)
at SeasonVar.getPlaylistURL(SeasonVar.groovy:102)
... 1 more
serviio.zip
(13.95 KiB) Downloaded 1384 times
Sony Bravia 2010 - KDL-32EX40B Serviio 1.9.2 Pro on Windows 7 x64 SP1/macOS Sierra 10.12.6/Ubuntu Mate 17.04 x64
Jurijlv
Post Thu Oct 08, 2015 1:58 am
Yes it is not working... sad time. Probably again they have made some changes. Have a hope that someone knows how to fix the problem and will update season plugin.
Thank you.
qanatoz
Post Sun Oct 11, 2015 6:30 pm
Jurijlv wrote:Yes it is not working... sad time. Probably again they have made some changes. Have a hope that someone knows how to fix the problem and will update season plugin.
Thank you.
Fixed.
Changes in version 10
  • Fixed minor issues after last site upgrade
  • Added support to select different translations. Supported translations: Any available for given season (example below in URL examples)
How to select translation:
ivanoff999
Post Tue Oct 13, 2015 6:40 am
Thanks, it's great job!
Jurijlv
Post Tue Oct 13, 2015 1:33 pm
Thanks a lot, works great!
lamo4ok
Post Fri Oct 16, 2015 2:49 pm
Нет звука, к сожалению.
Устройство, где стоит Serviio - NAS Dlink 327, Serviio PRO v 1.5.2 EVALUATION license - WebUI v 1.6.4
Устройство, где пытаюсь смотреть - стационарный компьютер, Kodi (Win7).
pikabu
Post Sat Oct 24, 2015 9:50 am
By default, the series are played with subtitles, the recommendations set translation is not working.
qanatoz
Post Sun Oct 25, 2015 8:26 pm
pikabu wrote:By default, the series are played with subtitles, the recommendations set translation is not working.
Fixed, download version 11
qanatoz
Post Sun Oct 25, 2015 8:31 pm
lamo4ok wrote:Нет звука, к сожалению.
Звук не связан с плагином, плагин только передает линки на видео в serviio. Если есть видео и нет звука то скорее всего это связано с настройками транскодинга.
Jurijlv
Post Mon Oct 26, 2015 3:14 pm
In v.10 there was not possible to select translation or movie source (LostFilm, To4ka), is it fixed in v.11
polinom00
Post Tue Oct 27, 2015 11:43 pm
sorry for my stupidity but can it be watched on English language if so .. can someone explain how?
Thanks in advance!
Jurijlv
Post Wed Nov 04, 2015 3:02 am
Hello, I have tried to choose translation but without success. Serial Black List season 3. It is possible to see only translation with to4ka. Can anyone help with this issue? Because they have stacked with to4ka on the film 3 but with the Lost they have already 5. And I cannot see Lost only To4ka.
Thank you very much.
P.S. have serviio on the NAS. Have tried everything described in main post, no result.
qanatoz
Post Fri Nov 06, 2015 6:57 pm
Jurijlv wrote:Hello, I have tried to choose translation but without success. Serial Black List season 3. It is possible to see only translation with to4ka. Can anyone help with this issue? Because they have stacked with to4ka on the film 3 but with the Lost they have already 5. And I cannot see Lost only To4ka.
Download version 12, install and use http://seasonvar.ru/serial-12470-CHerny ... n=LostFilm in url
Jurijlv
Post Tue Nov 10, 2015 10:35 pm
Thank you veryy much!!! Everything works fine! You are the best!
Jurijlv
Post Sun Nov 22, 2015 6:46 pm
Somehow plugin stoppped working again, doe sanyone knows why?
qanatoz
Post Mon Nov 30, 2015 2:13 pm
Jurijlv wrote:Somehow plugin stoppped working again, doe sanyone knows why?
Works fine for me. Can you send season url you trying to see?
Jurijlv
Post Thu Dec 03, 2015 5:15 pm
Just checked, everything works fine, sorry for that. Probably was some malfunction in my system after the update.
ka81
Post Wed Dec 23, 2015 10:08 am
sorry for being nubs, but - how to use/install plugin on OSx ?
pan Oleksiy
Return to Available plugins
